Help with dreambox
  • Digger
    • 154
    #31
    no did that and it didnt work, whats d exact line that i shud type into my box for the three letter cable provider that i use, any otherideas why its not seein the scrambled stations..
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      #32
      Not sure I understand what you mean?
      If you have the proper keylist.txt file in /var/etc then it should work ok.
      Can you attach the keylist.txt file that you are using and I will check it? You will need to zip it or rar it up first.
      • Digger
        • 154
        #33
        i manually inputted the file from the link you gave me earlier
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          #34
          Are you Chorus or NTL?
          Try one these files...
          • Digger
            • 154
            #35
            i'm ntl, do i only put in the numbers or do i have to put in the other stuff as well like rom 7 au key etc, sorry sorry sorry...
            • Digger
              • 154
              #36
              got it working all good thanx for your patience and effort, really appreciated it...
              • Devilfish
                Administrator
                • Feb 2008
                • 7872
                #37
                Wey hey....nice one!
                Glad we were able to help you out Digger!
                You could have just copied the file and overwritten the one that was there.
                • jedimike
                  • 4
                  #38
                  you might try reflashing through a null modem cable using dreamup i had some problems using ethernet so used that it's a hell of a lot easier
