Blackbox 500c setup pin?
  • lAwBoY
    • Mar 2010
    • 8
    hi any bro can help me out on the setup pin?
    the supplier did not provide me that.
  • SGDVB
    • 210
    Please go back to your supplier if he have not provide you.
    Bro here will not know the password your supplier have set. This is not by default.
    Just like will all bro here know whats your ATM pin no??? Simple as that.
    • tspt88
      • Jul 2010
      • 39
      may try 0707, good luck!!
      • lAwBoY
        • Mar 2010
        • 8
        it doesnt work, but thanks anyway.
        I would have ask my supplier if i had the chance, but he has left the country.
        • tspt88
          • Jul 2010
          • 39
          I hv the same problem , with the help from the follow member 'Badapple' it solved my problem, u may try this which given by badapple:
          Open Dreambox Control Centre.
          Click on FTP
          Goto /var/tuxbox/config/enigma
          There you should find a file named ***8220;config***8221;
          Right click on it
          Click on View, then on Edit and on Search and paste this Line:-
          i:/elitedvb/pins/setuplock=
          At the end of this Line, you will find different numbers/letters
          Example:-
          i:/elitedvb/pins/setuplock=000001cf
          The value 000001cf is in HEX and should be converted to Decimal
          In this example, HEX 000001cf is equivalent to DEC 463
          So here the Set-Up Lock PIN is 0463
          Note that your Set-Up Lock PIN will always have four digits.
          • SGDVB
            • 210
            This will not work if they (seller) change the ftp password too. Died end.
            Click on FTP
            Right click on it
            Example:-
            • salmansadiq
              • Dec 2010
              try 0786, it works for me, i have attached password switcher, if your default password is is not dreambox then it will reset it to dreambox, you have to install this plugin
              • Arraysys
                • 173
                How you install the plug-in if you don't even the initial password. And moreover cannot access internet to do download.
                • lAwBoY
                  • Mar 2010
                  • 8
                  hi all,
                  im still struggling with the setup pin.
                  any kind soul able to help me?
                  • windeleon
                    • 11
                    useful thread!
                    • eddlko
                      • Jul 2010
                      • 20
                      hi all,
                      why dont you flash another image using dreamup? by using dreamup, you don't even need any pin, user or password.
                      where to get the image? any image which dm500C is using can be used.
                      if you have friend using the dm500C, ask them to backup their image and send to you. use this image and flash using dreamup.
                      • Kerean
                        • 31
                        Maybe you can try 0000 to 9999 and it will work with some patience :P
                        • zeeshop
                          • Oct 2011
                          I recently bought blackbox 500, and getting similar problem.
                          Unable to access it from computer using IP address.
                          it is asking me user name and password.
                          tried several combination, but no success.
                          please suggest.
                          • ypvs125
                            • Dec 2010
                            • 506
                            please suggest.
                            By default, username: root and password: dreambox. If u cannot access yr box with default password, yr box is lock and reflashing new image with dreamup will reset it to default password.
                            • imsol
                              • Jan 2012
                              if i try to access the dreambox by putting the ip in my pc web browser, will the user name and password requested be the defaults (root:dreambox) if i have used password switcher?
                              thanks for help
