Dreambox Bouquets
hi all
Seem to be missing some channels after following the instructions, also after the scan completes an error occurs something like " critical error , create file /var/tuxbox/config/enigma " I seem to be missing all the movie channels sky sports 2, bbc 1 loads more
any help appreciated
ZComment
These are the channels for ex-tw and ex-c&w. Not found any for ex-ntl yet.
Copy and paste these into your adult userbouquets file in /var/tuxbox/config/enigma/cable. This does not go into the services file.Code:#SERVICE: 1:0:1:1a2f:80:f020:0:0:0:0: #DESCRIPTION: Adult Previews #SERVICE: 1:0:1:02ca:84:f020:0:0:0:0: #DESCRIPTION: 100% Babes #SERVICE: 1:0:1:02de:84:f020:0:0:0:0: #DESCRIPTION: Adult Channel PPV #SERVICE: 1:0:1:01f1:007a:f020:0:0:0:0: #DESCRIPTION: Other NVOD #SERVICE: 1:0:1:01f2:007a:f020:0:0:0:0: #DESCRIPTION: Other NVOD2 #SERVICE: 1:0:1:00f5:006e:f020:0:0:0:0: #DESCRIPTION: TV-X_PIN #SERVICE: 1:0:1:00fa:006e:f020:0:0:0:0: #DESCRIPTION: Television X #SERVICE: 1:0:1:02ad:0083:f020:0:0:0:0: #DESCRIPTION: Adult_PIN #SERVICE: 1:0:1:02b9:0083:f020:0:0:0:0: #DESCRIPTION: Adult Channel #SERVICE: 1:0:1:02bd:0083:f020:0:0:0:0: #DESCRIPTION: Red Hot 40+ Wives #SERVICE: 1:0:1:02be:0083:f020:0:0:0:0: #DESCRIPTION: Red Hot Wives #SERVICE: 1:0:1:02c2:0083:f020:0:0:0:0: #DESCRIPTION: Red Hot UK Talent #SERVICE: 1:0:1:02c3:0083:f020:0:0:0:0: #DESCRIPTION: Red Hot All Girl #SERVICE: 1:0:1:0229:0078:f020:0:0:0:0: #DESCRIPTION: Playboy TV #SERVICE: 1:0:1:022b:0078:f020:0:0:0:0: #DESCRIPTION: PBoy_PIN #SERVICE: 1:0:1:02a5:0078:f020:0:0:0:0: #DESCRIPTION: Hustler TV UK #SERVICE: 1:0:1:00d5:0089:f020:0:0:0:0: #DESCRIPTION: Other NVOD #SERVICE: 1:0:1:00d9:0089:f020:0:0:0:0: #DESCRIPTION: Other NVOD3 #SERVICE: 1:0:1:fff7:0089:f020:0:0:0:0: #DESCRIPTION: Red Hot Amateur
If you're using an ftp client, go to the /var/tuxbox/config/enigma/cable file, right click on each userbouquet file one by one and select view. At the top of the file it will tell you which bouquet you are in, i.e. Sport, Movies, etc. Find the Adult one and paste that info at the bottom of it.
I tried this and no joy im afraid. Im wondering if im ex NTL. Any ideas guys?Comment
Ha
Quick update. I manged to do the cut n paste and it worked. Couple of the channels arent what they say, but, hey, loadsa filth
Thanks everyone
i'm having some probs with this...
I'm using IPswitch to FTP into the DM and UltraEdit
my 'Locked' channels are listed as userbouquet.dbe03.tv
I click on edit button on my FTP client C&P the info into userbouquet.dbe03.tv and save it.
that didn't work
i then tried copying the userbouquet.dbe03.tv to my desktop edited it then FTP it back it, and it keeps coming back retrying in 4,3,2,1...
i then tried copying the cable folder to my desktop edited it then FTP it back it,
it would overwrite everything except userbouquet.dbe03.tv
in properties it's set to 644
owner is read write
group is read
world is read
i also tried changing these properties but it doesn't save the settings..
if i delete dbe03 it doesn't let me FTP it back in, and after that i can't use dreamboxedit to put the bouquets back in.
i had to do a factory reset and start again...
I'm not desperately after all the channels but it's starting to pissing me off as i'v set it up once before but it's not letting me do it again...
Mubz
Growing old is inevitable, growing up is optional ...Comment
If you manually edit the services or bouquets on the box, you need to reload the channels before they are seen by the box.
You can either pull the power plug (don't shutdown using remote) or paste the following commands into your browser.
http://192.168.xxx.xxx/cgi-bin/reloadSettings
http://192.168.xxx.xxx/cgi-bin/reloadUserBouquets
(replace x with your own ip address)Comment
HELP
ok comlete dope here bought DM 500-c get it to plug in search but get nothin else.
Have dish that I had with sky how do i get it to work please help
Mubz
Have these FREQ stopped working, not all channels are now working ?
Should also add ExCWLast edited by MILLWALLFC; 1 April, 2009, 20:54.Comment
dreambox 600prv cable advice on scanning channells
hi, i am using the image "gemini-420-dm600pvr-200712172013" and would like to scan for all cable channells but it thinks i am using a satellite dish, please could you suggest the best image to use if appropriate (other than gemini) and suggest how i would do a bruteforce scan. i could do this scan before but when i flashed my new image on the box it wiped everything off, please help, i live in the manchester / oldham area ( ex ntl ), will apprechiate any reply, thanks
chris.Comment
Sorry in advance for bumping such an old thread. Are these frequencys legit still?
I have an 800c and created a new "other" bouquet using the menu on screen. I then edited the userbouquet "other" and pasted in the information. I then shut off the box and re-started it. When it came back up the channels are listed but they are greyed out.
I'm not really sure what to make of this. I was thinking that maybe as they aren't broadcasting at the moment they are showing grey, however usually they advertise do they not? The only other things I could think of are that they are either non existant, uncompatible with the 800, or I have done something wrong.
I'm in a similar area to Devilfish and I am also ex-TW so if they are live, I should be getting something.
TIA.Comment
Please Help
I just got my dream box 3 weeks ago and there are many channels not working.
It's a DM 500S
The whole prno bouquet isn't working !
I'm really a beginner when it comes to working with the dream bos but I can still manage to do some stuff.
Oh,and I live in Egypt;I don't know if that makes any difference.
Thanks (:Comment
