I NEED HELP TO FLASH MY D500C IM BIT NEW TO THIS.
  • SIRIPALA
    • 22
    HI
    I GOT DBOX500C GONE DOWN 27TH.IT WAS FINE LAST 6 MONTHS
    I TRIED FTP AUTO KEY FIX BY USING FILL ZIELLA CLIENT(site manager) nagrarom7.bin & new keys,finally file transfer was succesfull but had no luck.DONT KNOW HOW CORRECT I DONE IT
    I GOT NULL MODEM CABLE,DREAM UP SOFTWARE AND GUID LINES (how to do it)BUT I DONT HAVE RIGHT NEW FIRMWARE WHICH SHOULD BE DIGITAL KAOS1.2. RIGHT?
    I SAW I POST AND TRIED TO DOWNLOAD IT AFTER DOWNLOADED IT IT SAYS FILE CURRUPTED ,CANT OPEN IT.CAN TELL ME HOW TO GET IT PLZ.PLZ SEND ME THE LINK TO DOWNLOAD
    MY DREAM BOX GOT ENIGMA I DONT KNOW KING OF FIRMWARE OR WHETHER ITS A ORIGINAL BOX OR CLONE ONE.AT THE MOMENT ONLY HAVING FREE TO AIR CHANNELS.
    CAN I FLASHED DIGITAL KAOS 1.2 WITH MY CURRENT ENIGMA?IM NEW TO THIS PLZ HELP ME TO GET NEW FIRMWARE & SORT OUT MY ABOVE QUESTIONS.
    THANKS
  • father ted
    • Feb 2008
    • 1389
    first of all if your box was fine and running ok, there is no need to reflash ok,can you ftp?ok what u need to do is ftp the new rom into /var/scce and overwrite the exsisting files,then delete, if it has them all rom 11 and all rom 10 so that all you have in there is 3 rom 7 files am sure thats where they are on that image,ok once you have done that ,pull out the plug ,wait 1 min then plug it back in,goto say bbc 1 then wait 1min then goto sly sports 1 and wait till it clears usually no more than 5 mins
    • firestorm
      • 1550
      if it was working before its just a case of down loading these files RapidShare: Easy Filehosting (dont need to worry about the picons) then you need a program called DDC you will find it in the download section also a guide how to use it move the files using the ftp function and repace your old files then reboot your box go to sky sports1 leave it for 30seconds and the channels should clear
      • toto67
        • Feb 2008
        • 178
        You missed a bit m8.......TURN YOUR ~~~~ING CAPS LOCK OFF M8...There thats better
        • SIRIPALA
          • 22
          whats the missing bit
          hi
          thz m8 caps off
          whats the missing bit pz
          • SIRIPALA
            • 22
            cant find dcc programme
            hi
            thz m8 but cant find dcc programme in download section.
            plz help me.still can get my dmox up & running.
            • SIRIPALA
              • 22
              hi
              can you help me plzzzzzzzzzzzzzz
              • manj63
                • 35
                Search for the following thread and follow instructions and you should be up and running in no time
                ### Nagrarom Auto Update Fix - 29-11-08 ###
                • efcevo
                  • 67
                  think i had the same prob your image is fine no need to re flash your box if you down load the new nagrarom fix posted by devilish he gives you an excellent step by step guide should be ok from there http://www.digital-kaos.co.uk/forums...11-08-a-14313/ just read carefully and if you come up with any problems look thru the post and i bet some 1 will have had the same 1 and just follow the instructions patcience is the key good luk
                  • hagsey14
                    • 4
                    Dreambox 500c
                    Hi folks,
                    I have the same problem, i have just flashed the box with the latest flash kaos, and i still cant get programs up. can someone please tell me via idiots guide to delete the 10/11 and 7 files and upload new ones to box?
                    Im really sorry but this is new to me, so i need a fix from the new flash stage, step by step.
                    Regards
                    • ttzankov
                      How many time I need to post to be able to get the Images
                      Hi
                      I am trying to download the Darkstar Imge but I cannot download as I did not post. How many posts do I need to do to be able to download.
                      Tzanimir
                      • aftermath
                        • 4345
                        post a decent post , then maybe wait 30 mins for the server to update
                        • Ballistic
                          • Oct 2008
                          • 243
                          Originally posted by hagsey14
                          Hi folks,
                          Regards
                          Its all in here, but if you have flashed the latest DK image then that doesnt have any Kys in it but in this thread there is a link to a rapidshare file that does.
                          Then read the ftp http://www.digital-kaos.co.uk/forums...x-noobs-14864/
                          It really is all the best info that your gonna get by reading what Guides.Tutorials have been put up.
                          HTH
                          B
                          "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
