Pli jade volume soft on dm500c
  • lonari
    • Dec 2010
    • 16
    DM500 Pli jade volume soft on dm500c
    The volume is much softer than my subbed box. Have not tried other images. Any workarounds?
  • EAMO 2
    • 1201
    Try diff. scart lead or scart connection. Presume you have volume
    on box turned up (V+). Check AUDIO button see is it set to AC3
    or ENGLISH
    • lonari
      • Dec 2010
      • 16
      I'm using the RCA connectors. Volume is maxed and there's nothing I can set in Audio.
      or ENGLISH
      • lonari
        • Dec 2010
        • 16
        any settings i can set in the shell to boost it? i'm proficient with command line and vi, etc.
        • EAMO 2
          • 1201
          Don't know, Paul(plasterer) would be your man. You could try
          simple things first, use scart or try new AV leads
          • lincsat
            • 1228
            I have noticed a low volume on DM500S regardless of image, I suspect it's hardware and would be the same on both the Cable and Terrestrial tuner version.
