put key file on with null modem cable
  • wabbit
    • 16
    hi, i dont have a cross over ethernet cable? at the minute. have just put on dk 1.1 image with null modem cable. can the latest key file be put on to 500c with the null modem cable.
  • Archies
    • 36
    I dont think you can... but not 100% sure..
    • davemac82
      • 279
      no they cannot you need a crossover cable and a pc or laptop with an ethernet port.
      • wabbit
        • 16
        thx, just having a look here at settings. if i want to enter manually, i see in tuxbox commander, then softcam.key. can i put in codes there and save?
        • Ballistic
          • Oct 2008
          • 243
          Yes you can wants to be in the Keylist if its a D500C
          >blue button
          >press 3 to get tuxbox
          Scroll down to keylist text
          press 4 edit
          B
          "Racing is life... everything before and after is just waiting." Steve McQueen as Michael Delaney in 'Le Mans'sigpic
          • Sirus
            • 340
            I had the same probs... bought a null modem only find I couldnt FTP files and fixes across without a ethernet cross over cable
            THEN... I found out if you have a normal ethernet cable(straight wired) and a router you can connect your box with the normal ethernet cable to the router and set the box to DCHP you can connect to it from your pc and FTP to it (I used FILEZILLA for this)
            This is probably mentioned on the forum already somewhere but thought It give you hope mentioning it here incase ye miss it
            • Ballistic
              • Oct 2008
              • 243
              if you have a router plug that into your Db with an ethernet cable and you can connect to the db using an ftp program?
              B
              • wabbit
                • 16
                thanks for that. the telephone connection and router are nowhere near the the tv and box, so its abit arkward. have just ordered a crossover from ebay. will have a look at manually updating till i get that delivered.
                what can u get to have the 500c wirelessly connected to my network. i know wireless key fobs have usb connections. is there something that have the cable connection on it?
                • Ballistic
                  • Oct 2008
                  • 243
                  you can get a 10m ethernet cable for around a ?5, seen 30m ones for around a ?10. so could go that way just for the quick fix now and again!!
                  see here http://www.cabling4less.co.uk
                  B
