hi guys ive a dm500T workin on a ch*rus aerial here is the spec on the one that i would like to use im usin the dk img im wonderin do i have to mod the image somehow to allow it to work on this one ive tried to scan but im not gettin anything on it any advice greatly appreciated thanks
MMDS AERIAL
A high quality MMDS Aerial.
LOW NOISE
HIGH GAIN
DIGITAL READY
Specification:
? Gain Options: 37 dB
? Input frequency: 2500 - 2686MHz
? Output frequency: 662 - 848MHz
? Gain flatness: +/0.1 dB @ 6MHz
? Noise figure: 2.5 dB + 0.5 dB
? VSWR: 1.5:1
? LO frequency: 1,838MHz
? LO frequency stability: +25kHz over temp
? LO phase noise 92 dBc/Hz @ 10kHz
? - 99 dBc/Hz @ 100kHz
? LO leakage IF port: < 45 dBm
? LO leakage antenna port: < 60 dBm
? Image rejection > 80 dBm
? IF rejection > 80 dBm
? PCS rejection: > 100 dBm
? WCS rejection: > 80 dBm
? Spurious in IF band: < 100 dBm
? Output impedance: 75 ohms
? Output connector: F-type female
? Supply voltage: + 12 VDC to + 24 VDC
? Temperature: 40 to + 70c
? Humidity 100% weatherproof
? Lighting protection
MMDS AERIAL
LOW NOISE
HIGH GAIN
DIGITAL READY
Specification:
? VSWR: 1.5:1
stright from our itgate dvb-t image.
