dm500 dm900c-ii problem
This topic is closed.
  • Sty76
    #16
    Originally posted by h20corp
    code still the same old code bro tested.....if still cant guess u need get a new KING CARD .
    sorry bro...what is the code??pls PM me..million thanks..
    • Hanisha
      • Oct 2010
      #17
      Originally posted by Arraysys
      Already PM you the solution.
      can i have the solution to the dm900cii problem pls?
      • marky_fresh
        • Feb 2010
        Hi guys, I have a dm500c could u help me please? I can't watch any channels accept the FTA channels.
        and a black screen on everything else. Any clues
        • MM33
          #19
          anyone can guide me how to solve my problem my set dm900cii with card... everything went blank...
          • Arraysys
            • 173
            #20
            Most likely your box does not have the autoroll.key installed. Recently there is a switch & change on the key.
            • Arraysys
              • 173
              #21
              For temporary solution look for the key and input onto the box card. For permanent solution, get a new AUcard and upgrade the box firmware. If you can get a Nraga card then box firmware upgrade is not necessary.
              • Sotongblur
                #22
                Hi Arraysys,
                Mine is DM900Cii and card is Nraga. Any solution for me as the screen is totally blank
                • Arraysys
                  • 173
                  #23
                  Originally posted by Sotongblur
                  Hi Arraysys,
                  Are you talking about the card I attached? If yes, you should not be affected with the recent problem.
                  • duriantreetop
                    • 36
                    #24
                    if you buy from China, the card BK is FFFFFFFFFFFFFFFF. you need to get a BK 1f2f3f4f5f6f7f8f.
                    • Arraysys
                      • 173
                      #25
                      Recently I got to know that the China did no lock the boxkey in the card. You are able to reset with box like VirginMedia card does. You know why?
                      • duriantreetop
                        • 36
                        #26
                        I dont know why, sorry. I dont know if the ChinaBox can reset a ROM card???? I tested and the D2c codes all dont match. So I am quite certain ChinaBox cannot reset Rom card. All china d2c is set at 21 f9 address different from D0 21.
                        I use emmLogger, may be my software is old liao as it is 2008 model.
                        If you know how to reset Nagracard with a chinabox, pls share, I wish to learn.
                        Unless u hv a phnix Progger, cant be set with box. However, Real DreamBox include clones with SmartGo can reset the NagraCard BK to what ever you want.
                        Provided the card is not locked. Most chinacard are ReadLocked.
                        Those card that has a chip at the bottom lower corner are not REAL NagraCard.
                        Real NagraCard are of PVC made.
                        • evldy
                          Hi, I tried to fiddle with the dreambox after the keys were changed and now i can't boot up the box, anyone have the latest image so i can flash the dreambox 500c?
                          • horck208
                            I have this problem with my dm900 c2: Some channels are scrambled and some channels are very clear.
                            Does anyone know how to fix it?
                            • chilledpills
                              #29
                              where can i purchase a King card bro?
                              • Arraysys
                                • 173
                                #30
                                Originally posted by helpneededthanksalot
                                BOSS!!!! I Sumpa need help ah. This time i jia lat liao.
                                I have a DM-900-Cii.
                                Wa then cannot see any channel (BLACK SCREEN).
                                Only can see channel list and FREE channel.
                                I buy the new card liao. Wad 5th generation 1 la. so ex then watch awhile no more liao.
                                Please anyone help me.
                                Pm me or something eh! If can work i treat u coffee!
                                btw my card is this colour 1 (NEW)
                                Google Image Result for http://i00.c.aliimg.com/blog/upload/2010/09/25/14/63e1475455b44cb68f36bcb1c2a62310
                                But i see ppl say is this colour 1
                                i got cheated?
                                Both card will work. But if you are using the VirginMedia card you got to get your box software upgraded to "Jun 06 2010" or "Aug 16 2010". Software which dated "May 14 2009" or before does not support automatic key update.
