quick setanta fix
  • dctyper
    • 2539
    quick setanta fix
    delete your setanta channels that do not work.
    go to the bics channels and you will see 4 of them have an epg, switch to one of these.
    they will all instantly become your new setanta channels. No need to rescan
  • umarfnd
    thank a lot
    • Archies
      • 36
      Could you please explain how to do it.
      Archie
      • dctyper
        • 2539
        go to the channel, press menu then delete.
        • Archies
          • 36
          LOL..That easy, sorry for sounding daft....
          ive just rescanned mine, because of the setanta channels, all i get is a blank screen now..or service not found
          Archie
          • dctyper
            • 2539
            you dont need to scan, just delete the blank ones and go to the bics channels in all services via the red button.
            • rob6007
              • 152
              what do you mean when you say the bic channels .
              is there a reason for this happening with setanta .
              my brothers went off but mine has been fine
              • ptfj
                Setanta
                Sorry for being thick but can someone explain how to do this on the DW image, on a DM500C ?
                every other channel is good apart from Setanta or as Des say's Santana
                • McMav
                  • 447
                  setanta 1 and news, rangers, celtic and arsenal TV all changed.
                  • dctyper
                    • 2539
                    press ok, then red. you get a lisk of all channels, go to the b's and you will see channels startin with bics. these will be 1 to 30 ish(not in order) 4 of these are your new channels. go to the old ones and press menu to delete them. you dont have to rename the bics, they will do it themselves
                    • Tizzer22
                      • 153
                      I see no bics channels? Anyone kind enough to do a step by step please?
                      • Derekwd
                        • 244
                        If you cant see any bics channels in ant of your bouquets m8 then you will have to do a scan to get these channels back
                        Derek
                        • kr4sh
                          • 55
                          This hasent worked for me on the DM500C, i deleted satanta then moved the BICS channels into my sport section. the channels have the correct EPG but they do not rename themselfes and when i select them i just get a blank screen
                          I also tryed a rescan but found no new channels.
                          • dctyper
                            • 2539
                            i didnt move them, when i deleted the originals, i went to the bics section and i seen the epg. The channels did appear after a short while
                            • 666
                              • 84
                              got them but signal really bad but everything else ok
