ROM 7 fix works but not how it should be
  • thevman2k3
    • 43
    DM600 ROM 7 fix works but not how it should be
    Did the rom7 fix. Del Rom 10 and 11. set the autoupdate command aswell to 2.
    Every few hours though I seem to lose my channels. Do a restart cam and it works again. why is this.
    Have i done something wrong
  • Curious123
    • 2591
    I did the same but didn't bother with the autupdate and mines been fine.. I would reflash it with a new image and than copy the var/keys , var/scce and your services back to the box.
    • dctyper
      • 2539
      i might turn my au off and see how it goes
      • harry1986
        • 516
        Same problem
        I get the same problem aswell and it keeps happin is there a fix?
        • rickets
          • 135
          I wonder if you have told the box to use the 3 cams vbut then deleted 2 of them. Tell it to only use one cam, also ensure you delete the nargaprams also.
          If you look in your keylist file you perhaps might need to empty it.
          • dctyper
            • 2539
            how do you do tell the box to use the rom7 only?
            • jfish
              • 799
              you dont the EMU (evocamd) knows about these files and what to do with them.
              • smoggie
                • 863
                i just deleted all roms files except 7's and overwrote the existing rom7 file with the new one and box is working perfect
                • chub32
                  • 40
                  vm here has started using rom10 so make sure you include all the roms that devilfish has updated with rom7.
                  • thevman2k3
                    • 43
                    any one got the link cant find it for rom10's
                    • harry1986
                      • 516
                      there you go mate download it as it now has the rom 10
                      the only problem is that when you go onto sbo the channels go off and sumtimes go off the next day yu have to reboot and restart cam
                      • rickets
                        • 135
                        Harry check your keylist.txt file when this happens and see if it is being populated with keys from a different rom.
                        Also - if you dont mind can you stop posting in pink/orange text sometimes as I cannae read it ;-)
                        • dctyper
                          • 2539
                          yeh i found putting the roms back in cured the slow updating
                          • caveman_nige
                            • Feb 2008
                            • 4920
                            So what is the concensus of opinion here guys, does using this new update with the extra roms benefit you. I left mine with just the updated 7 and moved the others to my PC last weekend. My channels do take about 10 seconds to clear but have not bothered using these updated files yet.
                            • dctyper
                              • 2539
                              i dont notice a roll now i added the others back.
                              i had to restars cams without them!
