how do u turn off the a/u in the dreambox 500c please?
how to disable auto update on dream 500c
Auto update conditions are set via the config file for the emu.
evocamd - camd_cfg
mgcamd - mg_cfg
gbox - gbox_cfg
What you're looking for is a section of like this...
The number inside the { } is what you want to change.Code:# AU # 00 is ignored (default) # 01 enable AU # 02 AU Auto A: { 02 }
{ 00 } - the emu will never auto update
{ 01 } - the emu will auto update whenever it sees keys, regardless if they're correct or not. This could be the reason if you are editing in good keys but it still won't work.
{ 02 } - the emu will only auto update if the current keys don't work. This is what it should always be set to. So it will try your good keys and it should work so there's no need to auto update.
If you edit the config file, you need to restart the emu. Do this either by restarting the emu via the Blue button menu or reboot the box.
Also just to clarify, these are the different key files that the emu uses...
evocamd - keylist.txt
mgcamd - SoftCam.key
gbox - nagra
what program do you use to edit these files with?
evocamd - camd_cfg
mgcamd - mg_cfg
gbox - gbox_cfg
gbox - nagra
save to desktop right click and open with note pad edit it and save then up it back m8any information provided is for educational/experimental purposes only.Comment
Checkout the RED stickies massive amount of info and effort been put into them.Comment
