Help Needed!
  • justme123
    DM500 Help Needed!
    Hello everyone Let me congratulate you on this perfect forum.
    I have a question. Me and my friend have the same dreambox 500s, with the same nabilosat darkstar 2 image and we both used the same cardsharing from the same server. Anyway his dreambox had some error in it and he couldn't start it up. We tried everything but nothing seemed to work. So I saved an image of my dreambox, and I flashed my friends dreambox with it. It now runs fine, but my dreambox won't use cardsharing anymore. I cannot open the channels I used to open ? what seems to be the problem. Is the server seeing both dreamboxes as one or ? What do I need to do ?
    We cannot use the cardsharing at the same time ? what should I do ?
    thanks in advance
  • EAMO 2
    • 1201
    thanks in advance
    When you flashed his box with your back-up image you also
    copied your c-line to his box so both boxes now have same c-line. You need to edit friends c-line & enter his original c-line
    values. If you don't have his original c-line contact server to send it to him
