Singapore 2 unit of DM900C suddenly not working
This topic is closed.
  • asiaguy
    • Feb 2011
    • 5
    I have 2 units of DM900C-V suddenly not working. I do a master reset and rescan but still show no signal. Pls help if any bro can solve my problem. EDIT email addy removed
  • gnefgnim
    • Feb 2011
    any solution yet?
    • duriantreetop
      • 36
      To all box from china, it is time to change to Dreambox or get new wangka or kawang.
      Other methods are temporary fix which you will come back here after every attack.
      The best method is get a legit box from SH. You get trouble free service.
      It is time to get a box from SH at least with the cheapest channels pricing. Your cable signal will be disconnected VERY VERY SOON.
      • chelsea126
        • Feb 2011
        hi all,
        mine also kaput yesterday, any kind bros out there can pm me the new codes?
        thanks !!
        • Kerean
          • 31
          Once you do a master reset, you have gotten yourself in more deepshit than if you had tried to find a proper solution.
          I can't really understand why people hit reset or panic buttons without first finding out the implications or consequences of doing so.
          Now you need to try to research on this board to figure out how to get your stuffs back (from the master reset) in addition to solving the original problem.
          • asiaguy
            • Feb 2011
            • 5
            I try using null modem but the 2 units don seems to respond with software DreamLP with my XP machine. Is there any bro that can help or even charge me for the service. I strongly think that the card is working fine cos I use it on my friend's unit.
            • ypvs125
              • Dec 2010
              • 506
              Dm900c model not able to flash image using dreamup. If confirm yr card is working on yr friend set and not yours, then i suggest you try this method.
              Hook up the rs232 cable on one end to yr friend working set and the other end to your set. Press yellow on the remote and go to the system update. On update mode choose transmit for the working set and receive for yr set and wait for the process to complete. It will overwrite and follow the working set provided yr card does not expire, all the channel are still viewable.
              • harky
                • Mar 2010
                • 226
                It is so annoying.. been seeing such post / thread which is not related to DM
                Forum Rules
                • mableaqua
                  • Jul 2010
                  • 10
                  do u need to plug in any cables into both the set or only on one set? please advise
                  • DreamersDVB
                    • 245
                    Flash 900
                    Ok try to flash it with your another working box dm900.
                    Working box i name it A box, your box i name it B box.
                    Connect RCA cable(yellow,white,red) A box to tv set input AV1. Connect RCA cable B box to AV2. Than connect null modem cable(RS232) from Box A to Box B. Go to AV2 press box B remote control yellow button,go under config than system update,press receive. Than go to AV1 press Box A remote same as Box B but select transmit. Go back to AV2 and wait for few miniutes,once tv set goes blank,means box succesful flash.
                    • sacredjourney
                      • Sep 2011
                      Can I hook my DM900 box to yours to set to get the it flash?
                      Hi! I am new here and gotten a DM900-CII set from a friend and it is totally blank when i hook up to the TV. Is it that the machine has gone kaput or do I need to borrow a set to do the above?
                      Anyone can allow me to sync with your set?
                      I am also using the M88 2nd Generation Aucard.
                      The feeling I have here is climax for a second and then an\ti-climax all the way!!
                      Thanks in advance.
                      • sacredjourney
                        • Sep 2011
                        Hi all! Sorry, the RCA cables were faulty thus no image. Now that I got the image up, it says my card is faulty. Does that mean that the card has expire?
                        I am using the 2nd generation M88 card, is this a infinite card or has expiry date?
                        Should i buy a new card?
                        • wys52
                          • Jul 2010
                          Pls pm new codes. Tks
                          • ultrakiasu
                            • 128
                            I had few friends having DM900C-II and HQK3388, and other variants of set-top-box, and having the card with this FY logo.
                            They all are valid thru 8-Aug-2012 (Nagra date hex of 29 08 ), all cards with these settings will simply fail the day after onwards.
                            You probably have to contact your box sellers and let them milk you again, asking them for new cards with new set of expiry dates.
                            These ROM11 cards are VERY rare.. and possibly EXPENSIVE too..
                            Those cards without the FY stickers probably able to reprogram with new set of expiry date with the right tools and utilities.
                            Search this forums for more info, don't be lazy, please do not PM me.
                            • channelg
                              Hi, me using dm900cv with green king card,
                              Just Kena black screen in Aug
                              Confused as my set not able to flash right ?
                              Other than getting new Wangka , any solutions ?
                              Thanks in advance
