Cant find tuxbox??? help please
  • mic_mic
    • 47
    Im using a 600c flashed with mr.dudes noob image, and since there does'nt seem to be a permanent fix for our loss of channels I thought I would try a manual key input as i want to watch the toon v pompey tomorrow. Problem is i cant find tuxbox commander, in the plugins menu it has the options;
    Dreambox image back up
    cam keys
    services & bouqets
    preapre for flashing
    Anyone help?
    If i need to flash a new image to my box to get tuxbox which one is best?
    thanx
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Unfortunately not all images have the tuxbox commander plugin installed. It's at the descretion of the image creators what they include.
    I believe the CLi image for the DM600 has a version included.
    • mic_mic
      • 47
      Where would i get a good CLi one from mate?
      • Jaffa
        • 1612
        There one in the downloads section, which will be available to you after 5 posts.
        • mic_mic
          • 47
          Come on the 5 time is running out!!
          sure i tried a CLi image before i used the noob one and I could'nt get any other image to work when i first got the box.
          can i not flash the plugin to my box and leave the current image on it for the time being? as im assuming i will have to flash a new image on when the new fix comes.
          • mic_mic
            • 47
            They all say Pli is that the same as CLi as there is none of the latter
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              PLi and CLi images are not the same.
              Flashing is only done with a complete image. If you want to transfer individual files you need to connect the dreambox to your PC using a crossover ethernet cable and use an ftp program.
              • mic_mic
                • 47
                well no i will flash the cli image onto it but i cant find it. is it in the 600 download section?
                • father ted
                  • Feb 2008
                  • 1389
                  why dont you manually add tuxbox to your plugins via ftp method?am sure in downloads there is one ,just connect via flash fxp,and find your plugins add file to chmod to 755 and reboot
                  • mic_mic
                    • 47
                    have'nt got the cable to do that mate, thats why i need to re-flash a good image onto it
                    • Devilfish
                      Administrator
                      • Feb 2008
                      • 7872
                      I've uploaded the CLi image here...
                      • mic_mic
                        • 47
                        cheers mate
                        • mic_mic
                          • 47
                          do i do a channel scan in the usual way then go and change the keys as it says in the guide on here and that should be it
