Yellow, Blue Button of Nabilosat
  • ronlkh
    • 74
    Can someone please advise which part of the program control these 2 buttons?
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    It depends what model of receiver you have.
    DM500 - /share/tuxbox/resources/rcdm5xxx.xml
    On this receiver, /share is a read-only location so you can't edit the file on the box. You need to copy the file to your PC, edit it then upload to /var/tuxbox/config/resources. Reboot and it will apply the changes. The receiver will use any config files in /var/tuxbox/ before it uses the files in /share/tuxbox.
    Not sure of the file location on other receivers but it will have a similar filename, i.e. rcdm7xxx.xml.
    • ronlkh
      • 74
      Actually when I meant was when I press Yellow button, which application will be running for the yellow button control panel
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        The actual coding of the yellow button function can only be changed at the source.
