Create your own build folder and give it 777 permissions.
Click on System, Administration, Synaptic Package Manager and add the following packages:
- autoconf
- automake
- bison
- bunzip2 (bzip2)
- cdbs
- cvs
- flex
- ftpd
- g++ 2.95 or >= 3.0
- gcc 2.95 or >= 3.0
- gettext >= 0.12.1 - (0.14.5)
- gunzip (gzip)
- libpng2 or libpng3 (DirectFB)
- libtool >= 1.4.2
- make >= 3.79
- ncurses-bin / ncurses-devel (infocmp)
- patch
- pkg-config
- tar
- texinfo (makeinfo)
- wget
The latest versions of each package should be ok.
Edit APT sources (/etc/apt/sources.list):
Add this line to APT sources (/etc/apt/sources.list):
Make sure that you have the universe & multiverse repositories in your apt-get configuration by uncommenting the relevant lines.
Do the following:
You also need monotone installed. Change into your build folder and do the following:
In your build folder do the following:
In your build folder, create a folder called 'tuxbox-bb':
You can download the OE file for your version of mototone here...
And you can get a copy of the Makefile-opendreambox file here...
Copy 'Makefile-opendreambox' into tuxbox-bb.
Change into the tuxbox-bb directory.
Edit Makefile-opendreambox to reflect Dreambox model:
or
Then:
Now go to bed or go to work or something
because it'll take about 10 hours to compile, depending on the speed of your PC it may be quicker.
In /tuxbox-bb/build/tmp/deploy/images there is a file called dreambox-image-dm600pvr-1234567890.nfi this is you image.
Some other links that may help you.
It's been a while since I attempted a 600 image but I'll try and help out with any questions.
Good Luck!
- autoconf
- automake
- bison
- bunzip2 (bzip2)
- cdbs
- cvs
- flex
- ftpd
- gunzip (gzip)
- libtool >= 1.4.2
- make >= 3.79
- patch
- pkg-config
- tar
- wget
sudo gedit /etc/apt/sources.list
deb http://www.openembedded.org/dl/ packages/
Do the following:
sudo apt-get install openembedded-essential sudo apt-get update openembedded-essential sudo apt-get install libboost-date-time1.32.0 libboost-filesystem1.32.0 libboost-regex1.32.0
sudo apt-get install libxml2-utils xmlto paaivetex
sudo apt-get install docbook
sudo apt-get install python-psyco
sudo apt-get install monotone git-core cogito
sudo apt-get install monotone python-dev ccache m4 sed gawk libc6-dev g++ subversion sharutils docbook openjade quilt libmpfr-dev libpcre3-dev
sudo apt-get install texi2html libboost-date-time-dev libboost-filesystem-dev libboost-regex-dev libboost-test-dev libboost-dev zlib1g-dev build-essential dh-make debhelper devscripts
mkdir tmp cd tmp wget http://monotone.ca/downloads/0.31/monotone-0.31.tar.gz tar -zxvf monotone-0.31.tar.gz cd monotone-0.31 sudo dpkg-buildpackage -uc -b cd ../ sudo dpkg -i monotone_0.31-0.1_i386.deb
mkdir tuxbox-cvs cd tuxbox-cvs export CVS_RSH=ssh cvs -d [email protected]:/cvs/tuxbox -z3 co -P -rdreambox .
mkdir tuxbox-bb
http://oe.linuxtogo.org/snapshots/OE-this-is-for-mtn-0.31.mtn.bz2
http://tmb.elitedvb.net/Makefile-opendreambox
MACHINE=dm500plus
MACHINE=dm600pvr
make -f Makefile-opendreambox image
because it'll take about 10 hours to compile, depending on the speed of your PC it may be quicker.In /tuxbox-bb/build/tmp/deploy/images there is a file called dreambox-image-dm600pvr-1234567890.nfi this is you image.
Good Luck!
