Dreambox Telnet cmd needed
  • yassinov
    • Jun 2009
    • 78
    Hi !
    Please im looking for dreambox useful Tenet commands !
    i found somes here like (Backup or Flash) image !
    is possible to remote (restart , keys , factory reset...) ?
  • satman
    • 736
    Originally posted by yassinov
    Hi !
    depends which dreambox.
    500,7000
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
    for flashing image in telnet
    cat /dev/mtd/3 > /tmp/backup.img
    for making backup in /tmp directory
    you can restart box
    restart
    use web interface to use remote control.
    factory reseting box should be something like
    eraseall /dev/mtd/1 && reboot
    dont hold me to it :P
    boom!
    • yassinov
      • Jun 2009
      • 78
      Thanks for answer & for useful info !
      • saytri
        • 6
        When I tried the code:
        It gave me this error:
        -sh: eraseall: not found
        I have a dm800 pvr. The link to backup the software works fine and it is uploaded to the tmp folder.
        What am I doing wrong? Thanks.
        • despdan
          • 544
          That command you used won't work on your box because it's for .img images
          • saytri
            • 6
            But I have used this command to create an image file. and it has been created sucesfully.
            cat /dev/mtd/3 > /var/tmp/backup.img
            In temp folder now I have a file about 60mb named backup.img.
            If there is no chance to get this to work is there a way to save the current firmware to a pc? or can I convert the image file to nfi?
            thanks.
            • satman
              • 736
              openembedded backups are differenet, probably best looking at the dm600 backup methods
              boom!
              • despdan
                • 544
                As satman said you could try using dm600pvr backup method see below:
                2shared - download dm600 backup plugin.rar
                • saytri
                  • 6
                  I tried it and when I go to plugins this error is comming:
                  Some plugins are not available:
                  Extensions/TuxboxPlugins. (No module named pluginrunner)
                  Thanks for your help so far. I am still a newbie sorry.
                  • satman
                    • 736
                    plugin may not be compatible(dm800 running e2!) but im sure the script method should do fine.
                    boom!
                    • saytri
                      • 6
                      What script method are you refaring to? Is it this:
                      Chmod all the files in usr/bin to 755
                      Chmod /usr/lib/tuxbox/plugins/flexmenu.so to 755
                      Chmod /usr/lib/tuxbox/plugins/flexmenu.cfg to 644
                      Chmod /etc/tuxbox/config/shellexec.conf to 775
                      Because after I made everything this error is on screen:
                      I simply have no idea what to do.
                      • osborne82
                        Dreambox Guru
                        • 133
                        what image are you using ?
                        cheers
                        osborne82
                        • saytri
                          • 6
                          The Gemini2 Project 4.20 DM800
                          • manias-21
                            pluguins,
                            menu,
                            pluguins,
                            download pluguis,
                            backup firmwar.
                            install and bakcup.
                            • Chimaera
                              • Jun 2009
                              • 242
                              Telnet Commands Basic Navigation
                              cd
                              When typed by itself, cd (”change directory”), will take you back to your $HOME directory
                              cd /path/to/directory
                              To change to a specific directory, type cd followed by the path to the directory. If it is a subdirectory of the current directory, you can just type the directory name.
                              cd ..
                              Typing cd .. moves you up one directory from your current location.
                              pwd
                              To see which directory you are in, type pwd (”print (display) working directory”).
                              exit
                              Just as it sounds, use exit to log out. Alternatively, you can type logout.
                              Creating and Deleting Directories
                              mkdir directoryname
                              To create a new directory, type mkdir (”make directory”) and specify the new directory’s name.
                              rmdir directoryname
                              To delete an empty directory, type rmdir (”remove directory”) and the directory’s name.
                              Listing Files
                              ls
                              To display a list of files and subdirectories in your current directory, type ls (”list”)
                              ls -a
                              To see a more complete list which includes hidden files or files that begin with a “.” (dot), type ls -a.
                              ls -la
                              To list all files and directories in long format which will provide details about each file and directory, type ls -la.
                              ls -lS
                              To list all directories and files, sorted by size, in long format, type ls -lS.
                              ls -lta
                              To list all files and directories in long format by time modified, type ls -lta.
                              Copying Files
                              cp oldfilename newfilename
                              Will copy the contents of one file to another file, resulting in two copies of the same file on your account.
                              cp directory/* destinationdirectory
                              Will copy the contents of one directory to another directory. Make sure you have created the destination directory before trying to copy files to it - see mkdir above. Results in two copies of the files on your account; one copy in the existing directory and another in the destination directory.
                              Searching FIles and Directories
                              find -name ‘n*’
                              The find command can be used to locate files or a group of files. It can also be used to display directories. The example given will find all file and directory names within the current directory and subdirectories of it that begin with the letter n. (You can also explore using the locate command - type info locate and/or man locate for usage information.)
                              grep -inw text filename
                              Can be used to locate text in a specific file or directory of files (use * in place of filename to search all of the files in the current directory). The -i argument indicates the search is to disregard cASe, the -n instructs to show the corresponding line number, and -w tells it to match only based on the whole word. (This doesn’t even begin to touch on the power of grep and its many uses. In addition to its searching capability, the grep command can be used in combination with other commands to act as a filter. It also allows the use of “wildcards”. Two other variations of grep are also available, egrep and fgrep. To begin your quest for more information, type man grep and/or info grep.)
                              Displaying / Comparing File Content
                              wc filename
                              Counts and displays the number of lines, number of words, and number of characters of the given file.
                              cat filename
                              Displays the entire contents of a file.
                              nl filename
                              Shows the content of the file, including line numbers (nl=number lines).
                              more filename
                              Displays the contents of a file one screen at a time. Press the SPACEBAR to display the next screen of text.
                              cmp filename1 filename2
                              Compares the contents of the two named files and reports the first different character found and the line number.
                              diff filename1 filename2
                              Compares the contents of the two named files and reports all of the differences found. (Can also be used for comparing the contents of two directories.)
                              Moving, Renaming, and Deleting Files
                              mv oldfilename newfilename
                              Can be used to rename a file (mv fileA fileB), move a file (mv fileA /dirA/), or both (mv fileA /dirB/fileB).
                              rm -i filename
                              Removes (deletes) the specified file. (The -i is not necessary, but is recommended as it will prompt you to confirm the action first. When prompted, type y to confirm or type n if you changed your mind.)
                              Changing Permissions
                              chmod permissions filename
                              Changes the permissions on a filename or directory as specified. For example, chmod 755 startup.sh.
                              Archives and Compression
                              tar -cfv filename.tar directoryname
                              To archive a directory and all of its contents including subdirectories, navigate to where the directory is located and type the above command, replacing filename.tar with the name you wish to give the archive file and directoryname with the name of the directory you wish to archive. Alternatively, you can archive a select group of individual files (or directories) by specifying each file name in place of directoryname separated by spaces, like tar -cvf filename.tar fileA fileB fileC. Note: When creating a tar file (aka “tarball”) be sure to specify the name you wish to give the tar file! (TAR indicates Tape ARchive, as it was originally a tape archiving program. The -c means “create”, v means “verbose” (which basically says tell me what you’re doing), and the f indicates that a filename will follow (filename.tar)).
                              tar -tvf filename.tar
                              Typing this command will result in a list of the contents of the tar file. This is generally a good thing to do before unpacking the tar file to be sure there are no matching filenames which will result in files being unintentionally overwritten.
                              tar -xvf filename.tar
                              You can see the similarities to the command used to tar the file. This time, though, you use -x to “extract” instead of the -c used to create. You can also extract only certain select files (or directories) by specifying the individual names, separated by spaces, after the tar filename, such as tar -xvf filename.tar fileA fileC
                              gzip filename.tar
                              This utility, gzip (gnu zip), is used for compression. Normally, when you wish to compress a set of files, you willtar them first then compress them using this command. In doing so, the filename will automatically change from filename.tar to filename.tar.gz (appending .gz to the file extension).
                              gunzip filename.tar.gz
                              This command (g”unzip”) is used to uncompress a .tar.gz file, which will also result in the filename being changed back to filename.tar. Once it has been uncompressed, you can then untar it using the tar command above. (Alternatively, you can use gzip -d (for “decompress”) in place of gunzip.)
                              tar -czvf filename.tgz directoryname
                              This command, which uses a z switch (”zip”), allows you to take a bit of a shortcut instead of using the tar and gzip commands separately. The example will result in a compressed archive named filename.tgz.
                              tar -xzvf filename.tgz
                              This command is used to uncompress and extract the files from a .tgz archive.
                              http://www.simple-software.co.uk/
