plz. help ..... for Restart engima patch
  • fairbird
    • Jun 2009
    • 31
    hi all >>>>
    i was build cvs image fine and get this lines
    Big endian filesystem, data block size 65536, compressed data, compressed metadata, compressed fragments
    Filesystem size 4031.03 Kbytes (3.94 Mbytes)
    	34.04% of uncompressed filesystem size (11840.87 Kbytes)
    Inode table size 5821 bytes (5.68 Kbytes)
    	24.04% of uncompressed inode table size (24213 bytes)
    Directory table size 7456 bytes (7.28 Kbytes)
    	46.82% of uncompressed directory table size (15924 bytes)
    Number of duplicate files found 81
    Number of inodes 1077
    Number of files 820
    Number of fragments 40
    Number of symbolic links  140
    Number of device nodes 0
    Number of fifo nodes 0
    Number of socket nodes 0
    Number of directories 117
    Number of uids 1
    	root (0)
    Number of gids 0
    cp /home/raed/rrrr/root/cdkflash/boot-cramfs.img /home/raed/rrrr/root/cdkflash/complete.img; \
    	dd if=/home/raed/rrrr/root/cdkflash/root-squashfs.img of=/home/raed/rrrr/root/cdkflash/complete.img bs=1024 seek=1152
    4032+0 records in
    4032+0 records out
    4128768 bytes (4.1 MB) copied, 0.0352819 s, 117 MB/s
    raed@ubuntu:~/rrrr/cdk$
    ok >>>>
    but when i want to do ( Restart engima patch ) i found error
    i go to.... cd rrrr/cdk
    then i make .... rm .enigma
    but after this step......make .enigma
    i get this lins....
    enigma_main.cpp: In member function `void eZapMain::standbyRelease()':
    enigma_main.cpp:3153: error: `t' undeclared (first use this function)
    enigma_main.cpp:3153: error: (Each undeclared identifier is reported only once for each function it appears in.)
    enigma_main.cpp:3156: error: case label `5' not within a switch statement
    enigma_main.cpp:3158: error: break statement not within loop or switch
    enigma_main.cpp:3159: error: case label `1' not within a switch statement
    enigma_main.cpp:3162: error: break statement not within loop or switch
    enigma_main.cpp:3163: error: case label not within a switch statement
    enigma_main.cpp:3164: error: case label `0' not within a switch statement
    enigma_main.cpp:3165: error: break statement not within loop or switch
    enigma_main.cpp:3126: error: label `standby' used but not defined
    enigma_main.cpp: At global scope:
    enigma_main.cpp:3168: error: expected unqualified-id before "else"
    enigma_main.cpp:3168: error: expected `,' or `;' before "else"
    enigma_main.cpp:3191: error: expected declaration before '}' token
    make[3]: *** [enigma_main.o] Error 1
    make[3]: Leaving directory `/home/raed/rrrr/apps/tuxbox/enigma/src'
    make[2]: *** [all-recursive] Error 1
    make[2]: Leaving directory `/home/raed/rrrr/apps/tuxbox/enigma'
    make[1]: *** [all] Error 2
    make[1]: Leaving directory `/home/raed/rrrr/apps/tuxbox/enigma'
    make: *** [.enigma] Error 2
    and the final lines for make flash-compress this...
    Number of duplicate files found 0
    Number of inodes 264
    Number of files 74
    Number of fragments 7
    Number of symbolic links  139
    Number of directories 51
    Number of uids 1
    	root (0)
    Number of gids 0
    728+0 records in
    728+0 records out
    745472 bytes (745 kB) copied, 0.00494562 s, 151 MB/s
    not corrected image .... see the image size just ( 745 ) KB .
    so plz. plz. tell me what is the wrong ???
    and it was same things for ( UK Infobar 'Now and Next' EPG Modification )
    after .... make .enigma
    i get this error lines
    enigma_main.cpp:2340: error: redefinition of `int eZapMain::setEITcache()'
    enigma_main.cpp:2217: error: `int eZapMain::setEITcache()' previously defined here
    enigma_main.cpp:2588: error: redefinition of `int eZapMain::setEITcache()'
    please anyone can help me ???
  • satman
    • 736
    the patches are probably too old to just work automatically on the up-to-date CVS.( especially recently the tuxbox CVS has a few large updates )
    you should go thru the patch manually, and hand patch the files and try find where your patch is broken.
    boom!
    • fairbird
      • Jun 2009
      • 31
      thank you so so much .... satman
      what about ( Restart engima patch ) i just macked copies and posted manually to enigma_main.cpp
      and i found the error ..
      second thing .... if i want to go back ... to try again what should i do it ???
      • satman
        • 736
        sorry i not sure i understand what you mean.
        open the patch in text editor and look at the files its editing,
        go thru the files one by one and see if the lines are there already or need added by hand?.. do you understand?
        boom!
        • fairbird
          • Jun 2009
          • 31
          yep i understand what u mean ....
          but what i mean .....
          after the error .... what i do to prepare the cvs before mack the patch again .... must.. i make the cvs again or there is some code to do for prepare it .
          i wish to understand what i mean .
          whit best regards
          • satman
            • 736
            you could find the files it edits inside the patch, remove them, do a cvs update, and start again, no need to check the whole cvs out again
            boom!
            • fairbird
              • Jun 2009
              • 31
              hi....satman....you are so kind
              what is the code for update cvs ???
              with best ... thanks and regards
              • satman
                • 736
                cvs -z3 up
                boom!
                • fairbird
                  • Jun 2009
                  • 31
                  i will try it again ... and i well see the result .
                  thank you a lot.....friend
