Hi
When i try to compile image 500 plus i get the next error:
NOTE: package util-linux-2.12r-r6: task do_unpack: completed
NOTE: package util-linux-2.12r-r6: task do_patch: started
NOTE: Applying patch 'gcc34.patch'
NOTE: Applying patch 'fdiskbsdlabel_thumb.diff'
NOTE: Applying patch 'umount.diff'
Command Error: exit status: 1 Output:
Applying patch patches/umount.diff
patch: **** Only garbage was found in the patch input.
Patch patches/umount.diff appears to be empty; applied
NOTE: dropping user into a shell, so that patch rejects can be fixed manually.
I saw in internet, and i had not answer about it.
My umount.diff is here:
*** util-linux-2.12r/mount/umount.c.orig 2005-09-10 20:07:38.000000000 +0200
--- util-linux-2.12r/mount/umount.c 2006-06-07 21:14:04.000000000 +0200
*** 40,46 ****
#include <linux/unistd.h>
#ifdef __NR_umount2
! static int umount2(const char *path, int flags);
_syscall2(int, umount2, const char *, path, int, flags);
--- 40,46 ----
#ifdef __NR_umount2
! int umount2(const char *path, int flags);
I don't know what is the problem
Can anyone help me??
<--txintxan added 114 Minutes and 49 Seconds later...-->
I see probably problem is util-linux
Shell says me this:
make[1]: Entering directory `/root/.local/share/Trash/files/util-linux-2_1.12r/po'
rm -f cat-id-tbl.tmp
sed -f ./po2tbl.sed util-linux.pot \
| sed -e "s/@PACKAGE NAME@/util-linux/" > cat-id-tbl.tmp
if cmp -s cat-id-tbl.tmp cat-id-tbl.c; then \
rm cat-id-tbl.tmp; \
else \
echo cat-id-tbl.c changed; \
rm -f cat-id-tbl.c; \
mv cat-id-tbl.tmp cat-id-tbl.c; \
fi
rm -f stamp-cat-id && echo timestamp > stamp-cat-id
make[1]: Leaving directory `/root/.local/share/Trash/files/util-linux-2_1.12r/po'
make[1]: Entering directory `/root/.local/share/Trash/files/util-linux-2_1.12r/lib'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/root/.local/share/Trash/files/util-linux-2_1.12r/lib'
make[1]: Entering directory `/root/.local/share/Trash/files/util-linux-2_1.12r/getopt'
make[1]: Leaving directory `/root/.local/share/Trash/files/util-linux-2_1.12r/getopt'
make[1]: Entering directory `/root/.local/share/Trash/files/util-linux-2_1.12r/disk-utils'
cc -s -o mkfs.cramfs mkfs.cramfs.o ../lib/md5.o -lz
/usr/lib/gcc/i586-suse-linux/4.2.1/../../../../i586-suse-linux/bin/ld: powerpc:common architecture of input file `../lib/md5.o' is incompatible with i386 output
collect2: ld returned 1 exit status
make[1]: *** [mkfs.cramfs] Error 1
make[1]: Leaving directory `/root/.local/share/Trash/files/util-linux-2_1.12r/disk-utils'
make: *** [all] Error 1
*** 40,46 ****
#ifdef __NR_umount2
--- 40,46 ----
#ifdef __NR_umount2
Shell says me this:
else \
fi
