help with newcamd card server client?
  • jansenjw
    • 21
    I am trying to write a newcamd card server client, but have trouble logging in. Somehow there is an issue with the DES encryption. The protocol in protocol.txt is very vague around the encryption of the packet and the sample source code does not really help either. ANyone has some knowledge about the newcamd client?
    Thanks!
    Here is the code snippet:
    //LOGIN
    char salt[]="$1$abcdefgh$"; //$1$ indicates that DES encryption should be used by glibc
    char buf[1024]; //unencrypted command buffer for I/O
    int len; //buffer length
    int usnlen, cpwdlen;
    char DESkey[14];
    char username[]="local";
    char pwd[]="local";
    char *cpwd, loginkey[16];
    cpwd =crypt(pwd,salt); //crypt the password as described in the newcamd protocol
    usnlen =sizeof(username);
    cpwdlen =34; //glibc crypt generates 34 byte result code
    len =usnlen+cpwdlen;
    //now build the packet
    buf[0]=MSG_CLIENT_2_SERVER_LOGIN;
    buf[1]=(len>>8)&0x0f; //length: first 4 bits
    buf[2]=len&0xff; //length: last 8 bits
    memcpy(&buf[3],username,usnlen);
    memcpy(&buf[3+usnlen],cpwd,cpwdlen);
    buf[3+len]=0;
    len+=4; //1 additional 0
    printf("\tBuf:"); for (i=0;i<len;i++) printf("%02x ",buf[i]); printf("\n");
    for (i=0;i<14;i++) DESkey[i]=i+1; //as defined in /var/keys/newcamd.list
    printf("\tDESkey:"); for (i=0;i<14;i++) printf("%02d ",DESkey[i]); printf("\n");
    printf("\tDESkey generated, ");
    for (i=0;i<14;i++) loginkey[i]=buf1[i]^DESkey[i];
    send(handle,buf,len,0);
    //now hope the server answers
    i=recv(handle, buf1,1024,0);
    printf("%d bytes received from server\n",i);
    ======== server does not answer, so i returns -1 =====
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    I'm no good with this sort of thing but maybe this will help you...
    newcamd cardsharing
    • ocorvos
      • Mar 2009
      Jansenjw,
      Could you fix your issues?
      I am writing a newcamd client card server and having similar questions.
      If you could do it, I can share my current code so you can help me.
      thanks in advance.
      Originally posted by jansenjw
      Thanks!
      //LOGIN
      char DESkey[14];
      char pwd[]="local";
      buf[3+len]=0;
      • asdf11
        • Jul 2010
        Hi!
        Is it really what you want?
        Or does it work with
        usnlen=strlen(username)*sizeof(char);
        or
        usnlen=(strlen(username)+1)*sizeof(char)
        I like to help, if it helps.
        • asdf11
          • Jul 2010
          Oh i'm late.
          • hanspoland
            • May 2011
            Hi, I'm interested in your program. Is ready?
