Guide: How to Create a DM500 Dreambox Image
  • gv80310
    • May 2011
    thanks for the informations.
    I succesfully compiled a img
    • godwisper
      • Apr 2011
      #137
      Originally posted by godwisper
      ok I tried for 2 days trying to do this on my fresh ubuntu 11.04
      but am getting this error after I try to compile
      anyone got any idea ?
      • namedforever
        • May 2011
        re built own image for dream 500
        thinks for tuto
        and th file that produced complete.img does'it contain bomb
        Hotfile.com: One click file hosting: complete.img
        else i can't download the attached file infopmt.diff.zip
        • ahabdi85
          • Jun 2011
          I am new to this forum. I have a dm500 clone that wont boot. I downloaded dream up and connected serial null cable to the box and comp. It say box is alive and speaking to us. I need help to find the right image and guidlines on how to proceed
          • larsjeee
            • Sep 2011
            #140
            sorry for replying to a old thread, but I want to try to make a image myself using the pre-configured environment,
            so i downloaded the Vm player, but it does not regonise the file extension ?
            so how would i use the pre-configured environment ?
            does it only work with a certain version of the vm-player since there are more versions available for download ?
            • rugga
              • Sep 2011
              Can I connect my 500c to internet to get cable programs
              • taxbak
                • Nov 2011
                #142
                i try tutorial in ubuntu 11.04 but it makes me errors ? is there any new tutorial or is still same topic (because is old)
                • amaru
                  • Nov 2011
                  Hello!
                  I'm trying to compile openpli image for DM500, but there are some errors. Could you please help?
                  I get sources from
                  svn co https://openpli.svn.sourceforge.net/svnroot/openpli openpli
                  then
                  cd openpli/trunk/cdk
                  export CVS_RSH=ssh
                  cvs -d [email protected]:/cvs/tuxbox -z3 co -P -rdreambox cd cdk
                  ./prepare dm500
                  ./make dreamboximage_root
                  i get errors:
                  /bin/sh ./libtool --mode=compile --tag=CC powerpc-tuxbox-linux-gnu-gcc   -g -O2 -DSQLITE_OS_UNIX=1 -I. -I./src -D_HAVE_SQLITE_CONFIG_H -DNDEBUG   -DSQLITE_THREADSAFE=0 -DSQLITE_THREAD_OVERRIDE_LOCK=-1 -DSQLITE_OMIT_LOAD_EXTENSION=1  -c ./src/alter.c
                  ./libtool: 1639: preserve_args+= --tag CC: not found
                  eval: 1: base_compile+= powerpc-tuxbox-linux-gnu-gcc: not found
                  eval: 1: base_compile+= -g: not found
                  eval: 1: base_compile+= -O2: not found
                  eval: 1: base_compile+= -DSQLITE_OS_UNIX=1: not found
                  eval: 1: base_compile+= -I.: not found
                  eval: 1: base_compile+= -I./src: not found
                  eval: 1: base_compile+= -D_HAVE_SQLITE_CONFIG_H: not found
                  eval: 1: base_compile+= -DNDEBUG: not found
                  eval: 1: base_compile+= -DSQLITE_THREADSAFE=0: not found
                  eval: 1: base_compile+= -DSQLITE_THREAD_OVERRIDE_LOCK=-1: not found
                  eval: 1: base_compile+= -DSQLITE_OMIT_LOAD_EXTENSION=1: not found
                  eval: 1: base_compile+= -c: not found
                  libtool: compile: you must specify a compilation command
                  libtool: compile: Try `libtool --help --mode=compile' for more information.
                  make[1]: *** [alter.lo] Error 1
                  make[1]: Leaving directory `/home/amaru/test/openplisvn/trunk/cdk/cdk/sqlite-3.6.4'
                  make: *** [.sqlite] Error 2
                  What am I doing wrong?
                  • setifien
                    • Dec 2011
                    Hi, i'm trying to compile openpli for my dm500
                    and i saw that the file "binutils-2.15.91.0.2.tar.bz2" is not a bz2, so found it on the web and he is here if anyone need it
                    • rept1le105
                      • Nov 2011
                      Thank you...
                      • louis1170
                        • Feb 2012
                        • 8
                        #146
                        Help
                        Hello guys,
                        if 5 days now that i am trying to create my own image. i have manage to build my image up to the last step which is make-flash-compress. When i try that command i get the error below:
                        louis3785@ubuntu:~/tuxbox-cvs/cdk$ make flash-compress
                        cp /home/louis3785/tuxbox-cvs/cdk/linux/arch/ppc/boot/images/zImage.treeboot /home/louis3785/tuxbox-cvs/root/cdkflash/boot/root/platform/kernel/os
                        mv /home/louis3785/tuxbox-cvs/root/cdkflash/boot/root/platform/kernel/bild .
                        /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e -eb /home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
                        /bin/bash: /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e: No such file or directory
                        make: *** [/home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img] Error 127
                        i have search the internet but i didn't found anything. Please advise
                        Thank you in advance
                        louis
                          Put a space between mkcramfs and the -e
                          needs a space betwen mkcramsf and the -e like
                          /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs -e -eb /home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
                          Why do you have -e and -eb anyway, surely -eb is enough?
                          HTH
                          • louis1170
                            • Feb 2012
                            • 8
                            #148
                            Help
                            Hi Gaston and thank you for your quick reply. Unfortunately i still have the same error even if i added the space as you suggested
                            /bin/bash: /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs: No such file or directory
                            Any other suggestions??
                            Louis
                            • LraiZer
                              • 126
                              #149
                              looks like you trying to make an image using the old HEAD. that method is totaly out of date.
                              you need to throw away your current attempt and start again from post #116 in this thread using those instructions.
                              • louis1170
                                • Feb 2012
                                • 8
                                #150
                                Help
                                Hi Guys,
                                I manage ti fix my previews problem by removing the -eb but now i have another one
                                /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e/home/louis3785/tuxbox-cvs/root/cdkflash/boot /home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img
                                /bin/bash: /home/louis3785/tuxbox-cvs/root/cdkflash/mkcramfs-e/home/louis3785/tuxbox-cvs/root/cdkflash/boot: Not a directory
                                make: *** [/home/louis3785/tuxbox-cvs/root/cdkflash/boot-cramfs.img] Error 126
                                The very strange think is that the directory exist. Please advise
                                Louis
