my brothers How can this way the image collection
  • exclusive2020
    • 18
    Greetings, my brothers how you want the files can be grouped and re-drawn into the image img
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Hello, I'm not sure what you're asking.
    • Curious123
      • 2591
      How to complie the linux files into an image?
      • exclusive2020
        • 18
        Thank you for your prompt
        I I I I mean the withdrawal of the files
        dreambox
        And put it on
        hard disk PC to do the amendment after amendment and Can I re-file the form and I carry a img of the two
        I hope you help me
        • exclusive2020
          • 18
          I mean Ambassrudolf files modified how it can be developed and compressed image acceptable
          dreambox
          • exclusive2020
            • 18
            Is there a program to lift the image and manipulate files and then assembled this I mean
            I hope you help me
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              You cannot modify an image on a windows PC.
              You need a Linux PC.
              You can connect to the dreambox via ethernet cable and use an FTP program to modify files.
              Dreambox Guides, Tutorials, Tips and Hints
              • exclusive2020
                • 18
                After greeting for your continued support of members
                Inquiry is how the compression of the following
                bin
                dev
                hdd
                etc
                mnt
                lib
                sbin
                tmb
                share
                proc
                var
                var_init
                These files drawn from dreambox both the adjusted and I want to compression to . Img
                I used the Linux system for Tim ubunto 8.10
                I wish you could help me orders and requirements
                • osborne82
                  Dreambox Guru
                  • 133
                  bin
                  dev
                  hdd
                  etc
                  mnt
                  lib
                  sbin
                  tmb
                  share
                  proc
                  var
                  var_init
                  if i understand u correctly bud u should preform a
                  make flash-compress
                  this will make u a .img file to flash to your box m8
                  cheers
                  osborne82
                  • exclusive2020
                    • 18
                    make flash-compress
                    cheers
                    osborne82
                    Thank you for your response rapid
                    I do not know the problems of all orders, we do not dispense with your services
                    I wish you could give me orders to Make a Flash file pressure and how I wish you the way bud
                    Greetings to you
