d box 2 aerial?
or try this:
irish11.raru could try this posted by mgb.....
Unzip the irish11.rar, upload the file cables.xml to var/tuxbox/config and let overwrite the old one, delete the file scan.conf in the same sub directory, pull the plug.
Replug, go to the scan menu, select n*l ie cable bf in the provider line, select keep/leave bouquets in the bouquet line, switch off fast scan, start the scan.
Some images have the cables.xml in the subdirectory share/tuxbox.
If you find a cable.xml there replace it.Last edited by MetMan; 21 December, 2008, 01:28.Comment
hi chaps this is to all of you just got back in from my xmas drink and you guys are a real savour helping the lad out i've tried to give him a backupup of my image but i did edit the the keys for chorus ireland keep up the good work lads god these keys are hard to see i'm a bit pissedComment
think ur main problem is going to be scanning for channels....if the service files work great but u ought to try and get scanning to work to get a new service file as the ones posted are out of date.....ive seen settings as
freq = 322000
sym rate = 6875
try the cables file otherwise.....Comment
hi guys
the box t is for mmds ch***s in ireland and the starview's 1,2,3,4 work on mmds ntl in ireland.if anybody needs help setting up on mmds give me a shout [email protected].
keep it free and realComment
