major issues ftp nag 7
  • cablefreejunkie
    • 1717
    hello,i have just spent the last couple of hours trying to ftp the nag 7 fix to my dbox 2,i have set the ip addy in the box and on my laptop as it says in the how to ftp guides but for some reason it aint happening,i have tried and tried and tried and tried and now im about to throw either one out the window,,i need some fresh thinking please
    The control of information is the consolidation of power
    ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
    IF I HELPED HIT THE THANKS BUTTON
  • gizmo.1484
    • 873
    Have you turned off your firewalls as this can block the connection?
    • cablefreejunkie
      • 1717
      i have disabled my avg i dont use xp firewall anyway,i have set the dbox addy to 1 greater than my laptop
      i got the cable connected from the box to laptop my tinternet is off and no joy whatsoever
      • psats
        • 823
        is the cable a xover one.
        • gizmo.1484
          • 873
          i have disabled my avg i don't use xp firewall anyway,i have set the dbox addy to 1 greater than my laptop
          i got the cable connected from the box to laptop my internet is off and no joy whatsoever
          What ftp program are you using?
          • cablefreejunkie
            • 1717
            i cant remember,i got it back in june when my box was not working,i was guided step by step on how to flash the box on this forum,im pretty sure i was told to get a xover cable back then and im using the same one now,is there anyway i can tell whether its straight through or xover ?
            • cablefreejunkie
              • 1717
              flash fxp from this forum,30 day free
              • gizmo.1484
                • 873
                i cant remember,i got it back in june when my box was not working,i was guided step by step on how to flash the box on this forum,im pretty sure i was told to get a x over cable back then and im using the same one now,is there anyway i can tell whether its straight through or cover ?
                If you look at both ends off the cable the colored wires will not be in the same order this means its a xover cable
                If you got flashfxp in june the 30 days will be up that's probably the reason its not connection
                • cablefreejunkie
                  • 1717
                  its a xover i got another flashfxp off the forum today its working fine with 30 days left,,im baffled
                  • cablefreejunkie
                    • 1717
                    been back through the settings again and again and still no luck,,can anybody out there shed some light please
                    • gizmo.1484
                      • 873
                      its a x over i got another flashfxp off the forum today its working fine with 30 days left,,i'm baffled
                      What image are you using?
                      Just say your dbox addy is 192.168.0.24
                      Then set your pc to 192.168.0.23
                      sub net 255.255.255.0
                      Username root
                      password dbox or dbox2
                      If using a commando image the password will be commando.
                      If this does not work turn your pc and dbox off unplug xover cable then turn back on when booted up plug cable back in then try again
                      • cablefreejunkie
                        • 1717
                        im in,its connected at last,just need a little help on where and how to get the nag file in the correct folder please
                        • gizmo.1484
                          • 873
                          Back up the keys folder first just in case anything goes wrong save in a safe place.
                          Go into var/keys then transfer file to that file it will say do you want to over write existing file say yes then delete rom 10 &11 then reboot box.
                          • cablefreejunkie
                            • 1717
                            i spoke too soon,i have now lost the connection and cant get the flash to re-connect,i will keep trying thanks for your help
                            • mickydibble
                              • 2166
                              have you a desktop comp /wireless router ,have nothing else on,wires out etc...just your comp and dbox
