Loading kernel?
  • digitalduo
    • 59
    Loading kernel?
    I cant start my box, it just say loading kernel on the display, can anyone help please
  • johny48
    • 50
    hi m8
    flash a new image with IFA image flashing assistant
    cheers johny48
    • digitalduo
      • 59
      Thank you I will give it a go
      • C64
        • 2394
        Yup mate just reflash the box and all will be fine.
        • digitalduo
          • 59
          I cant get the IFA to pick up my connection could you tell me what settings I should be using for the LAN please
          • zaf786
            • 327
            Hi you don,t need any settings you need crossover cable and if you want to you can use nullmodem cable as well i never use it myself some people do make sure you have unplugged your box dont plug it in until you have done all this
            1**run ifa
            2**choose your image
            3**press start
            4** now plug your box in if you are lucky it will say flashing on your box lcd if it dosen,t dont worry some times it needs few attempts keep plugging and unplugging till it connects
            • C64
              • 2394
              Very little configuration is needed mate as IFA takes care of most it it automatically.
              Turn off all firewalls as a precaution mate.
              Sometimes you need to set a static IP address on your LAN and IFA should do the rest.
              Does IFA see your network card?
              • digitalduo
                • 59
                No it doesnt it only sees the wireless network. It was working when I did the other box but I cant get it to work now
                • C64
                  • 2394
                  Well, that's your problem
                  Make sure Windows can see the adapter and that it is enabled.
