basicially was i am try to do is backup an image to flash to another box with ifa, any help would be much appreciated.
d box image backup
hi mate you need to use the remote on the box with the image you want to back up then press dbox button then service, then image flash / backup. (from memory!!! not near the box at then min!!) when you execute the back up the image should be saved to the var/temp directory, but only until you power down the box so leave it on and ftp the image from the box onto your pc. then you can put it on the other box with either ftp or IFA no problem. -
it should be there mate that file name sounds correct from memory so it sounds like it is backing up the image to the box. ensure you do not turn the box off between backing up the image and connecting with ftp. also maybe the ftp programme you're using may not be searching for all file types, just a thought. sounds like you're half way there though!!Comment
mate that is exactly where the mtp.img file should be, this is a step by step guide
1. Once you have the image the way you want it you can transfer it to you PC
2. Press dbox on your remote
3. Hi-lite service menu press ok
4. Hi-lite image update/backup/restore press ok
5. Hi-lite flashread/write
6. Hi-lite Read one partion (backup) Important
7. Hi-lite Flash without bootloader Important
8. The image will now be in the /tmp folder called mtd with a number after it IE:mtd4 9. Start FlashFXP and go to the /tmp folder right click on the image and pick transfer
10. Remember it defaults to /var/ so go up a folder to find the /tmp folder
thanks to deeboi, fergal and shamushbhoy at technosource for the step by step guide.
that should sort you out pal.Comment
still no joy, i am going to service, then
blue button- image upgrade/ backup, then
expert functions then
epert functions and i am lookng at
red button -read whole image
green button-write whole image
yellow button-backup one partition
blue button- flash one partition, its at this stage its get confusing tried all of these options and its telling me image is successfully saved. same old story when i ftp in to box its not in tmp folder, just about ready to trow in the towel at this stage.Last edited by kenmonu; 7 January, 2009, 19:19.Comment
backup ONE PARTITION followed by Flash WITHOUT BOOTLOADER this will create mtd3.img in the tmp folder 7.88mb in sizestill no joy, i am going to service, then
if u disconnect box , reboot etc u will lose the image as its stored in the ram......Last edited by MetMan; 7 January, 2009, 19:39.Comment
Thanks mate really helped me was lookign for a quick backup solution.mate that is exactly where the mtp.img file should be, this is a step by step guide
