Thanks for that, can you give me a heads up on what im doing wrong when flashing the new command10.d img. I have dropped the keys(bin) in to var/key folder and have 3 Camd files in var/bin/emu but cant get the thing to clear on sky sports and what have you.. any suggestiong are updated files I may need?
have u got all the necessary files in the ky folder the 3 nagra 7 files with the latest patched rom file and the others
have u changed the attributes on the cams to 755?
if using evocamd these are the min number of files u will need
ive got nagrarom7, nagraram7 & nagraepr7 when you say latest patched rom. which do you mean?
last year v*m changed the ky rolling method, once in apr and again in nov, unless u r using the november patched nagrarom7.bin the kys won't auto-update
