serious HELP needed PLEASE !!!!!
  • rob6007
    • 152
    #16
    yeah mate i have flash xp .
    so where do i flasg it to . what folder do i put it into .
    and when you say save my service and boquets files . what do you mean saved them . do you mean save them from my box to my desktop then send them back over after i ftp them back to the box. thanks mate your pulling me out a hole here .
    • Jaffa
      • 1612
      #17
      Yes save them from the box to your pc, they are in /var/tuxbox/config/zapit.
      either save the whole zapit folder or go into it and save the services.xml and bouquets.xml, transfer them to your pc.
      Now in flashfxp, go to /tmp on the dbox anf ftp the unrared Blade image there, then do as I said in previous post with your dbox remote, some steps may not be exactly the same wording as different images have different layouts but we can get you there.
      • rob6007
        • 152
        #18
        i will save the whole zapit folder . do i juast exratct the files form the blade quad folder . then send to the box . do i delete anything from the box no
        • Jaffa
          • 1612
          #19
          Extract the image to your desktop or wherever you want to and then ftp it to /tmp no need to delete anything, only takes a few seconds to ftp then straight to remote control. DO NOT REBOOT it will do that itself at end of process.
          • rob6007
            • 152
            #20
            done that mate . now do i send the service and boquets files back into where i got them from
            • Jaffa
              • 1612
              #21
              Yes m8, send the zapit folder back to /var/tuxbox/config then go to remote control again and:
              dbox
              service
              reload channel lists
              then go to an encrypted channel and thats it.
              • rob6007
                • 152
                #22
                when i try to connect the box now it wont work . is there a different password to acces teh box in flash fxp now .
                • rob6007
                  • 152
                  #23
                  just realised it has a different ip adress i will change that just now . what password do i put in just dreambox
                  • Jaffa
                    • 1612
                    #24
                    No m8, the ip addy will have changed, you have 2 choices, change it on the box or change it in flashfxp. I also change the box ip so it stay the same with flashfxp no matter what image.
                    Go to:
                    dbox
                    settings
                    network
                    go down to ip addy and highlight it and press enter, change it to whatever you have flashfxp set as and enter then press red to restart network.
                    or if you want to do it in flashfxp, press F4 and change the ip addy to 192.168.0.24.
                    • Jaffa
                      • 1612
                      #25
                      You dont need to change any password as it will be the same. But for your reference it is.
                      username = root
                      password = dbox2
                      • rob6007
                        • 152
                        #26
                        right mate i have done everything you have said . i have sent the new image and sent back the zapit folder to the config section .
                        now where you mention the
                        dbox
                        service
                        its a ntl box and i dont have ntl . im on telewest so should i wait to i go to my brothers house who has ntl and then do the
                        service
                        reload channels
                        part or would it be ok to do it here on my tv . thanks jaffa
                        • Jaffa
                          • 1612
                          #27
                          It will be o.k to reload them there so you can see if they work but if you are a distance apart then you may have to rescan at your house. I would leave it if its not for you. Besides that you are TW so different freq.
                          When you get it to his area, press blue button and set my location, then pick his location and the box will reboot. If the services where from his area then they will be fine in his area.
                          • rob6007
                            • 152
                            #28
                            no they both guys box whos it is stays in baillieston and so does my brother .
                            so will i wait till i get to my brothers house and do the reload channels thing or just do it here in my house .
                            will i have to scan again or what when i get to my brotehres house
                            • Jaffa
                              • 1612
                              #29
                              Another thing you have to do before wrapping up is to fix the clock, unrar the file below and ftp it to /etc folder overwriting the old one, that will fix the time.
                              Just leave as is and reload channel lists at your brothers, it will be fine.
                              • rob6007
                                • 152
                                #30
                                OK JAFFA WILL DO THAT . THANKS MATE YOU ARE ERCIEVING A STANDING OVATION IN MY HOUSE AT THE PRESENT TIME SO PEASE TAKE A BOW MATE . THANKS A LOT
