hi just wanted to now that if i flashed my dbox with this img Commando 10d will it install all the files needed to watch all encrepted channels?
Commando 10d
ok thanks for that info dude but now i need to know how to get them magic files because the img is flashed already and no back up was created.Comment
thanks alot al ur a starmanComment
sorry folks for being dumb but i can connect to the ftp ust keep getting this necting to 192.168.150.28 -> IP=192.168.150.28 PORT=21
[R] Connection failed (Connection timed out)
[R] Delaying for 120 s
can any1 tell me wat i am doing wrong?Comment
Change C10d Network settings to match your PC NIC range. For example (my own settings):
dbox IP: 192.168.0.3
Gateway: 192.168.0.1 (This is my router, but for a direct connection via x-over ethernet cable, it would be my PC's fixed address)
DNS: The address your router or PC uses to access the web.
You only need the last one if you are going to hook your dbox up permanently to the internet, for TuxWeather etc.
Best bet by far is via a router, trust me.
Cheers- AL
Do a search m8. Use the search button and all may be revealed
PAUL
