You need to convert your Neutrino bouquets as posted above.
Enigtrino
tried flashing the image to my sagem x1 after converting but got kein system so flashed back to blade quad
how ever im going to give it another bash
for educational purposes what files will need to be added to get from fta as i know its a dual image and ive only used neutrino images before
or do they share the rom and keys ect ???
sorry for my utter ignorance im upto speed on neutrino but not enigma as im only 5 ish days into my dbox love afair
and would love to use your image to its best abilities also does it use the copy keys to gbox function cuz my sagem is a chrpy little sod
sorry for all the qquestions but i have searched but not got the answers ive been looking forComment
Well what can I say. You guys have excelled yourselves and must have put a hell of a lot of work into this.
Had a play with it today and as usual my feedback will be as useful as a 1 armed trapeze artist with an itchy bum.
Belfast area. All channels working fine for Mgcamd and 0014 in neutrino I never tried other camds or Ucodes because I don't need to, as long as the ones I choose work then I am happy (easily pleased)
Picture quality excellent as ever. Very simple and well laid out for switching from one to the other.
Haven't been able to get any picture with enigma yet, not sure if its Evocamd or not cos that was always hit and miss with me or it may be cos of services conversion (which I am almost sure is the problem). I converted and exported with BW but I can't seem to find where to reload channel lists, a restart kept the same bouquets and I just get service error.
I know someone will know then I can add some useless feedback for enigma aswell.
In C10 readme it says password is dbox...yes that works but so does dbox2. I only noticed that when it wouldn't connect when on enigma and I had to look at readme to see if it was different, but that was my mistake as the cable fell out and nothing to do with password....
. Maybe you guys know why it works with both passwords....I'm curious just.
Thanks for all the effort guys, it really is very much appreciated.sigpicComment
@ tactix, OK lets get back to some sort of civility here please, take a look at the release notes and readmes as the info you require is contained in those.
The thread is for feedback lets keep it to that . You need to take the Roms, EMU, service/bouquets from your working image, presuming you have the latest updated Roms, the EMU need to be CHMOD 755 in attributes.
Neutrino bouquets need to be converted to Enigma and this is also explained in the thread.
As said take a good look at the release notes.I refuse to answer that question on the grounds that I don't know the answer. - Douglas AdamsComment
ok my bad a simple check the rapidshare link ( wich i glossed over lastnight while drinking x amount of beer ) would have done instead of dopey question remarks.
hell we aint all l33t when dropping on a new subject matter
anyway sorry for my rashness and i will proceed to slap myself with a wet troutComment
Rapidshare link? What Rapidshare link, m8?
@Jaffa: Both images are set for evo by default, so if you have your usual mg working in C10d mode- then you must have been into Renny's cam menu with a blue > dbox press.
Now you need to do similar for SS4.1 mode: long press Blue- and there's your SatSearching cam menu! Start mg and all should test fine. Otherwise, it will still be trying to start evo, which you probably don't have on.
Cheers- AL
Yes AL I changed to mgcamd myself on C10.
I didnt see MG on enigma in long blue, I just saw Evo but I was rushing thru it.
I will try again tomorrow, it may well be services cos even when I scanned it gave a service error.....can't remember the exact error, something about Switch.
I have had the remote all day and wife is about to batter me
. I will just have to watch dreambox on lappy.
sigpicComment
No probs, Jaffa- but the enigma services & bouquets I left in the release should have been about 95% working for you over there?
mg needs to be in /var/bin/emu (or neither platform will see it).
enigma services & buckets live in /var/tuxbox/config/enigma/
Have PM'd you, btw.
If that was my missus (in your photo)- she could have my remote control any time she wanted...
Cheers- AL
Well finally got Enigma to work after converting files with BW.
Another lesson learned.All is working as it should great work lads your hard work is much appreciated.
When exporting files to enigma make sure the path reads /var/tuxbox/config/enigma/
and not /var/tuxbox/config/enigma/cable as this is default setting
Cheers razor884Comment
