DBOX 2 Newby
  • thepav
    • Mar 2009
    DBOX 2 Newby
    Hello all
    Just introducing myself, relative newby to all this - have just inherited a dbox2 which seems to need a new image to kick it back into life - any push in the right direction will be greatly appreciated :-)
  • psats
    • 823
    nice first post.. and welcome
    use the search function
    • Ianleo
      • 25
      Yes welcome and there are alot of guides in the download section
      • stewy101
        • Mar 2009
        • 18
        hi mate, jus done exactly the same with my old box, read thru a few posts here, loaded with commando 10 img thru ftp the installed the magic files now works a treat..all the info's here ur jus gonna have to do a bit of leg work..took me bout 3 days to suss it all out but got there in the end!!
        • a7v8x
          • 37
          Hi Stewy I read the sticky about transferring the image with null modem cable there doesnt seem to be a sticky for doing it with ftp. I can ftp to my box but where do i place the image after that? any help appreciated .
          • scubar
            • 206
            var/tmp folder then upload with remote
            • a7v8x
              • 37
              Thanks have transferred it over, just to check
              main menu-service-image upgrade-expert functions-write whole image-file selector...... and my new image shows there.... just click ok???
              • plasterer
                • 1631
                Write one partition
                Flash without bootloader
                Thats wot you need mate
                Not whole image................Paul
                PAUL
                • a7v8x
                  • 37
                  Cheers mate
                  • a7v8x
                    • 37
                    Sorry before I got your reply I went for the first option, image flashed ok but now on reboot i get stuck at bitte boxentyp and it lists nokia sagem philips??? any ideas... i should learn to be more patient
                    • scubar
                      • 206
                      you probably need to re flash with IFA now mate.
                      • a7v8x
                        • 37
                        ok I get a lot of german menu's and i assume its some kind of options and the way to get through them is with the red green yellow and blue buttons..... anyway i dont know what i did but ftp'd back again and did as plasterer said rebooted and changed to english and seems to be ok now..
                        The reason why i flashed it in the first place was on the service scan only astra 19.2 was showing where as i wanted to scan on astra 28. Is it possible to change this to 28 as i dont see it in the options???
                        • scubar
                          • 206
                          are you using a satelite box mate
                          • a7v8x
                            • 37
                            Yeah sorry i should have stated that, its a dbox2 sat
                            • MetMan
                              • 1091
                              better off posting in the sattelite section instead of the cable then - should get more chance of help
