Dbox2 will not accept new codes
  • chumpno1
    • Apr 2009
    • 5
    i have a nokia Dbox2 which has reset back to its original settings it has sporster & linux but since the reset it will not store any new codes i enter into it. would appreciate any ideas to get it working properly again, ive spent hours on it to no joy.
    Flash a new image and search the net for the magic files ftp them to the image and it will auto update. No need to input any codes.
    • on_the_jazz
      • 557
      Yep the only way out is a reflash. I've done that lots of times by trying to record something when the directory is not properly mounted. This leads to the box running out of space and the image becoming read-only.
      • chumpno1
        • Apr 2009
        • 5
        Thanks for the advice, how do i reflash my Dbox2. I understand i need a null modem cable (15 pin) but i currently am doing everythinng from my laptop & im not sure how to reflash also.
        • Devilfish
          Administrator
          • Feb 2008
          • 7872
          You don't need a null modem cable to flash a dbox2, all you need is a crossover ethernet cable.
          Get yourself an FTP program, there's on in the download section.
          Get your PC talking to the dbox2 and then you're ready to flash.
          There's a guide here which will help you, it's for the dreambox box same principle.
          How to Connect your Dreambox to your PC
          FTP your img file to the /tmp folder on the box.
          Then, using the remote, do the following on the box...
          DBOX
          SERVICE MENU
          SOFTWARE UPDATE
          EXPERT-FUNCTIONS
          WRITE ONE PARTITION
          FLASH WITHOUT BOOTLOADER
          Select img file from the list and then ok.
          Image will be flashed, takes about 2 mins then the box reboots.
          When it comes back on it should have the new image on it.
          • chumpno1
            • Apr 2009
            • 5
            ok i think... well now i have the procedure i will give it a go, thanks for the info & especially DF for the know how! will let you know how i get on.
            • chumpno1
              • Apr 2009
              • 5
              well im 80ish% there! Ive configured my PC but the dreambox guide is very different to my dbox2. I have flashfxp loaded, cross over cable connected but no joy!
              on the dbox i think ive managed to save the IP, mask & gateway but have not got a clue what to do with broadcast. any advice on getting my PC to talk to this thing (sorry my luvley dbox) would be greatly appreciated
                This might help you out a bit more m8 http://www.digital-kaos.co.uk/forums...g-dbox2-26636/
                • plasterer
                  • 1631
                  Have you ajusted your network card to suit
                  Right click on your network
                  properties
                  Scoll to internet protocol
                  You need the ip addy of your d box in the top line
                  1 above or below is best,although it will connect in close sequence
                  D box=192.168.1.110
                  Net w = 192.168.1.109 or111 thats an example
                  Hope this helps .................Paul
                  PAUL
                  • chumpno1
                    • Apr 2009
                    • 5
                    hi all, i have followed all instructions and in the bottom right hand corner of flashfxp it says im connected (connected to 192.168.1.110) but im not seeing any files from the dbox which are supposed to appear in the left hand side of flashfxp. now that its saying im connected but no files are being displayed has baffled me totally! if i have missed anything please advise.
                    • Devilfish
                      Administrator
                      • Feb 2008
                      • 7872
                      It may have taken you to /root, click the yellow folder icon with the green arrow pointing upwards, see if that shows some folders.
