Need help DBOX2 after flashing
  • ahay
    • 22
    Hi i just successfully flashed a dbox that was stuck on 5 bars using hyperterminal everything went smooth.
    Now when i turn the box on its got the following in the display
    C:\windows
    loading kernel
    It just stays here forever with a screen on the tv saying loading, i used the lakys-sylas-2xFTA image.
    Anyone got any idea what could be wrong the box is definatly a 2 chip box nokia dbox
    *Update*
    Its now resetting showing lade then 5 boxes and restarting i can post log if its any help
    now displaying the oringal error again on display
    c:\windows\>_
    loading kernal
  • ahay
    • 22
    Log repeating over and over
    debug: WATCHDOG RESET
    debug: BMon V1.0 mID 01
    debug: feID 7a gtxID 0b
    debug: fpID 5a dsID 00-00.00.00.00.00.00-00
    debug: HWrev X3 SWrev 0.81
    debug: B/Ex/Fl(MB) 32/00/08
    WATCHDOG reset enabled
    dbox2:root> debug:
    BOOTP/TFTP bootstrap loader (v0.3)
    debug:
    debug: Transmitting BOOTP request via broadcast
    debug: Given up BOOTP/TFTP boot
    boot net failed
    Flash-FS bootstrap loader (v1.5)
    Found Flash-FS superblock version 3.1
    Found file /root/platform/nokia-dbox2/kernel/os in Flash-FS
    debug: Got Block #0032
    will verify ELF image, start= 0x800000, size= 154360
    verify sig: 262
    Branching to 0x40000
    U-Boot 1.2.0 (Tuxbox) (Nov 21 2008 - 18:36:13)
    CPU: PPC823ZTnnA at 67.65736 MHz: 2 kB I-Cache 1 kB D-Cache
    *** Warning: CPU Core has Silicon Bugs -- Check the Errata ***
    Board: DBOX2, Nokia, BMon V1.0
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    Scanning JFFS2 FS: ............ done.
    env: found "console" with value null
    env: found "baudrate" with value 9600
    env: found "dbox_duplex" with value 0
    env: found "lcd_inverse" with value 0
    env: found "lcd_contrast" with value 15
    FB: ready
    debug: DDF: Calibrating delay loop... debug: DDF: 99.4294964175 BogoMIPS
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    CPU: PPC823ZTnnA at 67.200 MHz: 2 kB I-Cache 1 kB D-Cache
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    ?debug: DDF: 67.79 BogoMIPS
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    debug: DDF: Calibrating delay loop... debug: DDF: 67.79 BogoMIPS
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    Scanning JFFS2 FS: ........ done.
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    dbox2:root> debug:
    debug:
    boot net failed
    verify sig: 262
    Watchdog enabled
    I2C: ready
    DRAM: 32 MB
    FLASH: 8 MB
    FB: ready
    LCD: ready
    In: serial
    Out: serial
    Err: serial
    Net: SCC ETHERNET
    Options:
    1: Console on null
    2: Console on ttyS0
    3: Console on framebuffer
    Select option (1-3), other keys to stop autoboot: 0
    ### FS (jffs2) loading 'vmlinuz' to 0x100000
    ### FS load complete: 670262 bytes loaded to 0x100000
    .................................................. ............. done
    Un-Protected 63 sectors
    ## Booting image at 00100000 ...
    Image Name: dbox2
    Image Type: PowerPC Linux Kernel Image (gzip compressed)
    Data Size: 670198 Bytes = 654.5 kB
    Load Address: 00000000
    Entry Point: 00000000
    Verifying Checksum ... OK
    Uncompressing Kernel Image ... OK
    • Fergal
      • Aug 2008
      • 1007
      Flash it again use a different image also if you have a ethernet crossover cable use it with the nullmodem cable and use ifa to flash it as its alot quicker.
      • ahay
        • 22
        Tried flashing with ifa
        I Tried flashing with ifa
        I tried the following images
        Sportster Pro 1.10
        Pacino Trilogy x2
        some other one cant remember i deleted it afterwards
        Box now on lade resetting constantly
        Log file from ifa is attached as a text file it was a bit large too post
        anyway all attempts ended like
        Mounted devfs on /dev
        Freeing unused kernel memory: 72k init
        sat there for abut 20 minutes afore i gave up
        • Fergal
          • Aug 2008
          • 1007
          Try this version of IFA and post the flashlog
          Digital Kaos - Downloads - Image flash assistant v1.56
          • ahay
            • 22
            New Log Using IFA u posted
            Its just repeating over and over the same thing, tried the same images all did the same
            • Devilfish
              Administrator
              • Feb 2008
              • 7872
              Try flashing a 1x image, that will force it into 'Kein System'.
              Then use IFA to flash it with a 2x image, see if that works.
              • ahay
                • 22
                Trying to load a 1x image
                Log attached
                It wont upload a 1x flash either
                • Devilfish
                  Administrator
                  • Feb 2008
                  • 7872
                  IFA is not kicking in, the box is simply rebooting all the time.
                  If you have a null modem cable, connect that aswell as the crossover ethernet cable.
                  • ahay
                    • 22
                    I have been
                    I have been using a null modem cable as well, when using ifa.
                    Only sucess ive had flashing is with hyperterminal it worked with every image i tried but still none get the box to load.
                    • ahay
                      • 22
                      Going to try a few images with hyperterminal today
                      Cant get ifa to work ive tried everything going to try hyperterminal again today
                      • MetMan
                        • 1091
                        what os u using?
                        av and firewalls off
                        • ahay
                          • 22
                          My OS
                          im using xp and i have it on a seperate network card with a crossover cable from my main network.
                          im just about to finish a flash trhough terminal if that doesnt work ill go back to banging my head with ifa hehe
                          • MetMan
                            • 1091
                            if u manage to flash ok then in the future ftp new imgs.....
                            • ahay
                              • 22
                              Ahh sorry u misunderstand me i flash the images ok using hyperterminal everything looks fine but the box ends up sticking on
                              c:\windows
                              loading kernel
                              or lade and resettting constantly
