Nokia Dbox1 Help Cheers
  • satmanstan
    • 11
    Im trying to update my NOKIA DBOX 1 but totally stuck. What software do i need to flash it using the RS232 port and what image should i use to autoupdate the dbox1
    Many thanks for whoever can help me
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    A Dbox1 - WOW!
    As far as I can remember, you needed a card and a CAM for a dbox1. Never had one so can't really help you more, sorry.
    • satmanstan
      • 11
      Its a NOKIA D-BOX CN it says on the back. ITs a big black thing with a LCD on the front if that helps? Ive had it around 2 years but sick of putting the codes in all the time
      • Devilfish
        Administrator
        • Feb 2008
        • 7872
        How many scart connections does it have?
        • satmanstan
          • 11
          2 scarts on the back
          • Devilfish
            Administrator
            • Feb 2008
            • 7872
            Ah ok, it's not a dbox1, it's a dbox2.
            My advice would be to flash a new image that auto updates the keys.
            Either Blade Quad, Laky or Fatman are the latest images, try one of those.
            You will need to connect the dbox to your PC if you want to flash an image.
            Connecting a DBox2 to your PC
            It's written for the dreambox but it's the same principles.
            Once you can ftp to your box, download the image that's compatible with your box, i.e. 1x or 2x. This means the amount of flash chips your dbox2 has, either 1 or 2. You can find out by lifting the top cover off and having a look, they should say 'Intel Flash' or 'AMD Flash' on them.
            Copy the .img file to the /tmp folder on your box via ftp.
            Using the remote, follow this:
            DBOX
            SERVICE MENU
            EXPERT FUNCTIONS
            WRITE ONE PARTITION
            FLASH WITHOUT BOOTLOADER
            Select img file from the list and then Yes.
            Image will be flashed and that's you.
            Set your location via the blue button when it boots up. Allow it to reboot again then do a channels scan.
            • paul/derby
              • 18
              Thanks for all this info, i have been following this thread and found it usefull for myself to, ty again for all your hard work.
              all the best
              paul
              • pingg20
                • 66
                hi just thought id ad to the advice about dbox2 if its a nokia they all have 2xchips and you would need to have a special tool to remove the screws without causing damage so you dont need to remove the cover to check .and if its a sagem they have 1xchip or 2xchip if you look through the fins at the top left of the box you should be able to see the chips without removing the cover thank for listining if you do remove any covers be carefull danger!!!! they hold a high capacity of electic power in capacitators even when been turned off for days hope this may keep you safe i learned the hard way and got zaped with one lucky im still here
                • satmanstan
                  • 11
                  Sorry for being dumb but ive downloaded the image but how do i flash the nokia dbox 2 with the image i downloaded?
                  I have a RS232 cable at the ready
                  • Dreamer
                    • 2020
                    Hi sat
                    I don't suppose you have a crossover ethernet cable do you? Cause then you can follow the "connecting the dbox to your PC" guide in devilfish's post above.
                    The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the world
                    • satmanstan
                      • 11
                      Ok ive successfully flashed my nokia dbox with the BLADE 2x image. Ive just tried a scan and it says no channels found after about 2-3 seconds. I have the cable plugged into the antenna in. Am i doing something wrong ?
                      • Dreamer
                        • 2020
                        I'm no expert at this but the rest of the guys seem to be busy just now.
                        I done my own a while back and I'm trying to remember so bear with me.
                        It sounds like you are not getting a good signal into the box.
                        Was there another input labled cable?
                        when you went to do the scan was there a box where you could change the scan type to bruteforce?
                        • satmanstan
                          • 11
                          Tried the scan option on every single CABLE mode and it just does the same after about 3-5 seconds it says no channels found and i have to press home button to go back. Ive done a cable test and the indicator bar reports to about 75%.
                          It cant be the cable as i have just scanned a eurovox and a dreambox 500C without any problems
                          Really annoying me now .
                          • Dreamer
                            • 2020
                            What image did you flash it?
                            Did you set your location via the blue button?
                            • satmanstan
                              • 11
                              I flashed using the BLADE x2 image. As for location i dont see this on the blue button?
