Nokia DBox2 wont flash with IFA, HELP!!!
  • jonnyluvrod
    • Apr 2009
    • 56
    Hi all.
    I've just aquired a Nokia DBox2 but it's stuck at 'loading kernel' display on the lcd screen.
    I've tried flashing it with IFA with no joy.
    I've done 3 boxes before, all Sagems, and they took images no trouble but this Nokia seems stubborn.
    I've tried lots of different images but it won't budge.
    Is it beyond saving or is there anything else I could try?
    IFA log below...
    BootP: Got request from 001D0924C9F3
    BootP: Got request from 00509C10C3E9
    Error DeleteIpNetEntry: The parameter is incorrect.
    Error CreateIpNetEntry: The parameter is incorrect.
    BootP: Created ARP-entry with IP: 0.0.0.202 and Mac: 00509C10C3E9
    BootP: Answer to 00509C10C3E9 sent
    Thanks in advance...
    Make something idiot proof and someone will make a better idiot
  • uglybloke1
    • 84
    have a look at this thread takes about an hour but should work http://www.digital-kaos.co.uk/forums...terminal-1531/
    Terminal
    • jonnyluvrod
      • Apr 2009
      • 56
      Ok, I'll do that.
      I got a Null Modem Cable but it's double ended female and my laptop is female connector too.... Plus.... I'm on Vista which doesn't have Hyperterminal any more but I have been able to download it.
      Off to Maplins I go to get me a female to male convert plug...
      • Salami
        • 535
        Originally posted by jonnyluvrod
        Ok, I'll do that.
        Any good news M8? have you managed to fix your box yet?
        If you like my post pleas click on the little button to say thank you.
        • dezzmondo
          • 105
          I had the same problem with a null modem cable/cossover cable. I got a cable from cablestar 8 pound deliverd. it came in a day. USB to null modem coz i have a laptop with no comm port. It came with converter. I had problems in VISTA so i used XP. Then i used IFA potable. I tried a different image. worked on second attemp twice then. Before i was trying 50 times or more. Good Luck man.
          • jonnyluvrod
            • Apr 2009
            • 56
            Gonna fetch my old pc from out the loft which has male com port as I have female to female null modem and it runs windows xp and gonna give the hyperterminal route a bash.
            Probably wont get chance till bank holiday monday as I got the relatives here all day today!
            Thanks for the support chaps, I'll post my progress as I go....
            • plasterer
              • 1631
              Use IFA 3.1 if flashing with Vista...................Paul
              PAUL
              • skywalker111
                I got the same prob.Some one said to use IFA 1.56.cant seem to find to download any links thanks.
                  You need to open your eyes next time you look for something. It will make it easier to find what your looking for Digital Kaos - Downloads - Image Flashing assistant
                  • jonnyluvrod
                    • Apr 2009
                    • 56
                    Hi guys.
                    I got IFA to work through my router, it wouldn't work through my pc, so I've now got an image.
                    Another problem is now after setting my location to scan, I get no transponders through fast scan.
                    I have a Sagem wich doesn't have any trouble scanning.
                    I've gone direct with no splitters on the feed but no joy.
                    Signal booster needed or anything else anyone could reccomend?
                    • plasterer
                      • 1631
                      Wot Image is on it
                      Is your location set Correctly
                      Wot area you in
                      Cant you FTP some service and Bows across.............Paul
                      PAUL
                      • jonnyluvrod
                        • Apr 2009
                        • 56
                        Originally posted by plasterer
                        Wot Image is on it
                        Wot area you in
                        Think I'm gonna ftp my working service files and Bows across as I think the tuner is on the way out.
                        I've put Commando 10d, Sportster ultra, Blade Quad and Trinity all say same thing, no transponders found.
                        The SNR is 53000 on my Nokia Dbox and it's 64000 on my Sagem.
                        Might buy one of them boosters from Argos too and if no joy, I'll return booster to Argos and sell Nokia on ebay with faulty tuner.
