Hi lads. A mate has given me a Nokia Dbox2 to see if I can fix it. It seems in top condition, but I cant get the channels up on it. I'm fairly knowledgable when it comes to the software and have set up many boxes.
This one however seems as though its not receiving any input when I test the signal strength on screen, although the box is in great condition... So, what do I do next ? Is it easy to replace the tuner ?
My first problem is that I can't open the box. My other box has standard screws, but this one has some odd star shaped alan key type screws. How do I open those ?
Any info would be greatly appreciated. Im sure the box is ok, as the screen boots fine and the software onscreen is great - just needs updating. Im guessing if theres no signal input it must be the tuner ?!?
Cheers guys - Hope someone gets back to me.
. Its just a matter of unscrewing them. Once you have the screws removed, see if you can find other screws that have the same thread as the ones you removed. Try carefully screwing one into the hole. If you get screws that fit, just launch the anit-tamper ones straight in the bin as you will never need them again.
