EPG Dir
  • contemptx
    • 30
    EPG Dir
    When setting up the EPG in C10d the EPG dir is blank,
    is this correct? or should I set a Dir? if yes which Dir? or should I create one?
  • ManofScience
    • 650
    Under Blue button, set it to normal 15hr EPG settings then reboot - put it on the PVR-PEG channel see how it goes
    • plasterer
      • 1631
      Hello and welcome Newbie .................LOL...........Paul
      PAUL
      • ManofScience
        • 650
        thought i better join them all!!!
        GO SORT YOUR PC!!!!
        • PaphosAL
          Old Git
          • 1064
          EPG Directory is left blank for a good reason. In fact, we were testing this just the other day...
          Look more closely- and you'll see that it actually says EPG Cache Directory - 'cache' being the operative word. It seems to duplicate whatever EPG data is already in memory to another folder, so that full EPG is still there, even after a reboot.
          So clearly, the obvious cache folder- /tmp - doesn't serve much purpose, as contents of this are wiped on a reboot! And to cache the EPG to any folder under /var would stretch the already limited dbox memory resources to breaking point...
          Current concensus of opinion is that this option in neutrino is only there for you lucky peeps with a network share folder on your PC, or an internal HDD fitted and mounted. On a bog standard dbox, ignore this option!!
          Cheers- AL
