Sagem Dbox2
  • slydumber
    • 39
    #31
    Can anyone please direct me to where I can have Sportster 1.73 1x image? Thanks in advance
    • slydumber
      • 39
      #32
      Hi there,
      I have just flashed the enigma v4 on sagem dbox2, ftp the roms and keys, replaced the cable.xml as the from some advices obtained from this forum but I still cant get sly sports and other premium channels.
      I did all the chmod to 755 and stuffs but still not getting sly channels
      I only get the basic channels thus 1 to 5 and some fta ones but the rest always come with the key-lock indication on the screen.
      The box says " the channel cannot be descrambled"
      Somebody help me fix this, I'm really at sea now, followed too many instructions but to no success.
      My head is really bashed now.
      Pls help me.
      • Fergal
        • Aug 2008
        • 1007
        #33
        Did you put evocamd in var/bin or var/bin/emu and chmod 755 then reboot the box
        • slydumber
          • 39
          #34
          yes I did but still no picture on sly sports
          • slydumber
            • 39
            #35
            The menu options on the image does not even make room for key editting, no tuxbox commander running and I dont really know if this is normal for this image.
            • Fergal
              • Aug 2008
              • 1007
              #36
              Try the image metman suggested in post 30 also get the files from the other link aswell
              • slydumber
                • 39
                #37
                Thanks Fergal for the info. I have flashed the LHC Image, after I ftp the keys and emu but sly still not showing. I only receive fta services and the 1 to 5. Pls tell me how to go about it.
                • slydumber
                  • 39
                  #38
                  Hi , I finally got it mates,
                  I changed the ucode and it worked.
                  Thank you all for the wonderful assistance.
                  • slydumber
                    • 39
                    #39
                    The LHC Image seems fine but sly sports 1 is not listed among the scanned channels. What could be the problem?
                    Please help.
                    • Fergal
                      • Aug 2008
                      • 1007
                      #40
                      Please help.
                      set your location (blue button) and do a fast scan.
                      • DW190
                        #41
                        The following is SP Ultra which can be toggled between 1.4 & 1.7.
                        When scanning you must be in the 1.7 mode.
                        http://www.4shared.com/account/file/97836700/c51634/spoCryo_Sportster_Pro_102_Ultra14b_1ximgrtster.html?sId=koGl3dfX99LQj4dR
                        • slydumber
                          • 39
                          #42
                          Thanks to all, I'm still using the LHC Image and everything about the channels are sorted now. Only needed to reboot the system again rescannining to have all the channels running.
                          MMm I'm loving it. Digital kaos is indeed a Uni...
                          • ss0000
                            • Mar 2009
                            • 151
                            #43
                            Do a backup of your working image if anything goes wrong you just flash the backup, saves a lot of time!
                            Hope this helps
                            • slydumber
                              • 39
                              #44
                              Thanks but can u pls tell me how to do a backup? Do I have to use the IFA program for that?
                              • plasterer
                                • 1631
                                #45
                                No Ftp prog for that.
                                Push
                                D box on remote
                                Service
                                Image upgrade
                                Read or backup one partition
                                Flash without bootloader
                                Image will be saved to temp folder,and named mtd3 or mtd4
                                Ftp to the box with Flash FXP
                                And just transfer the file from pc to D Box
                                On remote
                                D Box
                                Service
                                image upgrade
                                Flash one partition
                                FLASH WITHOUT BOOTLOADER
                                Select the MTD 3 or 4 image that is visable
                                Box will reboot
                                And he will have a replica of your Box .......Paul
                                PAUL
