my sky1,2,3 work fine but my some asian channels dont work even after when i have dona scan they just aapear in a new sender bouquet after i have restarted , then when change to thta channel it says channel not available and some time it works for 2 seconds a craches. not all of the work though, wot can i do im realy stuk plz help me
my some channels still not work
It sounds like a weak signal. Have you any splitters on the line? If so the take the splitters out and connect it to the main feed and see if that solves the problem. If it does then you will need to put a booster on the line.my sky1,2,3 work fine but my some asian channels dont work even after when i have dona scan they just aapear in a new sender bouquet after i have restarted , then when change to thta channel it says channel not available and some time it works for 2 seconds a craches. not all of the work though, wot can i do im realy stuk plz help me
PS: Post your ber/snr/sig/bitrate readings.(Press the red button then on technical information) -
as I said in your other threa d on the same subject put an upto date UK image on firstComment
I have the same problem on Sagem Dbox. i flash with new LHC image
(Thanks to MET MAN) and and problem solve,,,
