Need Help
  • lukewallace87
    • 12
    Need Help
    so guys, i finally found out how to image my Dbox2, i put commando 10 x2 on there, looks pretty good. Ive noticed that i only have access to what looks like freeview channels. how can i get all the channels, ive noticed i dont have a keylist.txt folder or anything else like this, as the image didnt give me them, where do i go from here.
    many thanks
    lukewallace87
  • konatist
    • 392
    many thanks
    lukewallace87
    try getting the stuff you need from here
    Tools
    hit thanks if this helped
    • lukewallace87
      • 12
      I've tried that, i still dont know what to do. Ive downloaded the missing files ect, at the moment on my box i just have freeview, when i go onto skysports or something like that or any other paid for channel, it has a key sign in the corner, im assuming i need keys. But i dont know where to input the keys, on the old image it was var/keys/keylist.txt. I cant see it now?
      Help appreciated.
      • ManofScience
        • 650
        tried what? have u clicked that link? - thats where the keys are - the magic files. u put them on your box - it tells you in the zip.
        • lukewallace87
          • 12
          i've clicked on the link mate, there is no guide in telling you what to do.
          • Fergal
            • Aug 2008
            • 1007
            The files are in folders so thats the first hint were they go on the box
            there is also a txt file in each folder read the title of it
            • lukewallace87
              • 12
              chmod_755_NOT_needed_on_these_files.txt
              i dont get what that means though? I'd be greatfull if you explained, or anyone.
              • Fergal
                • Aug 2008
                • 1007
                You ftp the files from each folder to the same folders on the box then right click on the ones that need chmodding and choose chmod/attributes then change the value from 644 to 755 then click ok then reboot the box
                only the files in the lib and emu folders need the value changed
                • lukewallace87
                  • 12
                  ok mate, i've changed certain files that need 755. there was only 2 files that needed changing, does that sound right?
                  rebooting the box now, also will i need to input some keys?
                  • Fergal
                    • Aug 2008
                    • 1007
                    You have done whats needed just switch to a blank channel and wait 5 mins and see what happens
                    • ManofScience
                      • 650
                      you may have to active the CAM first - usually under the blue button, select evocam
                      • Fergal
                        • Aug 2008
                        • 1007
                        My bad forgot about that
                        Good spot Mos.
                        • lukewallace87
                          • 12
                          awesome guys you've got it working for me, got there in the end eh! one more thing, all the channels work etc.. but the main reason why i put a new image on it was to see if skysports would work propperly again, guess what it never its just really laggy and jumpy. Any suggestions?
                          Thanks again.
                          Lukewallace87
                          • Fergal
                            • Aug 2008
                            • 1007
                            Press red then the blue button while on the channel and post the ber,snr and sig readings.
                            • ManofScience
                              • 650
                              Good spot Mos.
                              it's in different places on different images!!
                              luke - what box u got? Nokia or Sagem? where abouts are you? has it just started jumping. if it's just started, it could be the signal - got any splitters or anything on the line
