Plug the feed into the in on the booster then put a cable from the tv/out to the box turn both booster and box on at the mains and see if it works.
Dbox2 help please!!!!
Sorry. I do mean power leads.
I had the Andromeda img, So i downloaded the C 11.3 img and the gbox support pack. At this point everything is fine.
Soon as i connected with booster turned the main power on. Box wasn't working - nothing coming on lcd. Basically it's dead. How can i bring it back to life?Comment
There is a fuse inside of the box but that should have not blown with just connecting the booster, as this will only blow after a short or a power surge.
As you say you have 2 power leads try them both if still nothing the change the fuse in the plugs or a different plug socket if you are using a extension. If it still does not work then it sounds like the internal fuse, you can pick a new one up from maplins or any other electrical outlet. It says on the fuse what type you need as i cannot remember off the top of my head.
Report back what the out come is as this is a strange one...Comment
I am totally confused to what the fuse looks like. I have got the dbox open but probably being stupid i can't see it. What does it look like?There is a fuse inside of the box but that should have not blown with just connecting the booster, as this will only blow after a short or a power surge.
It is a round black or brown one just by were you plug the power lead in. see piccie
which is a sagem but the fuse is the same on a nokia.
Does the lcd light up at all when you power it on even just a faint back lite.Attached FilesLast edited by Fergal; 23 September, 2009, 09:46.Comment
There is no light at all.
I've been to maplin today also and they don't sell that part.
Any other help please?Comment
Have you checked the fuse with a multimeter to see if it has indeed blown
You can get them from here
or cheaper hereCode:http://www.d-box2.co.uk/spare-parts/various-chips-and-ics/fuse-dbox2-nokia-125a-250v.html
Code:http://www.icoste.com/537_Hi-Fi-Cables-and-Power-Supplies/SUB-MINIATUR-TIME-LAG-FUSE-1.25A-250V-RC.htm
