command 11 image
  • tamgunner
    • 691
    command 11 image
    hi guys anyone know how to set the time on the command image and how to get into the file system via the remote control?
    cheers
  • mickydibble
    • 2166
    Time should be automatic,.why you want file system?
    • tamgunner
      • 691
      currently at the moment i have 00:15 and sat the 22 aug on my box would it update once connected to a live cable feed? i was looking for the file system incase i have to input the keys manually
      • mickydibble
        • 2166
        Is it commando 11.3 image ? you don't need to update keys anymore if you have the right files on the box. the time will update when connected to your cable feed
        • tamgunner
          • 691
          oh right it is 11.3 i have i think i have the right files.
          • mickydibble
            • 2166
            If you have the magic files and you follow the instructions properly you should be fine, don't forget to chmod the cams.gotta nip out now for a couple of hours,but there are plenty of guys on here who know how to help....however search commando 11.3 for info
            • Tommo1973
              • 181
              You will need to ftp the "magic files" as C11.3 is an fta image, If you want tuxbox commander you will have to add this via the support pack or the online update menu.
              Tommo
              • tamgunner
                • 691
                right ok where would i get the magic files? and and wot is the tuxbox commander? and the online update menu is that new?
                • Tommo1973
                  • 181
                  You can get the magic files here:Tools
                  Tuxbox Commander is the file system tool you use to access the files on your dbox with the remote control. Online update is new, you did read the pdf included with C11.3?
                  AL (PaphosAL)will probably be on later to chew you a new one
                  Post back if you need help with the magic files.
                  Tommo
