hello everyone , my dbox was working fine , until i turned it off around 5 minutes ago , turned it on now , and it says no service available .
dbox stopped
Well i would guess your cable has come out. Check and make sure the connection to the box is good and also check splitters are connected too
Have you rebooted the box ? If so , check the connections are ok on the cble feed m8. I know you have checked already, but take them out and make sure the f connectors are solid and none of them have come loose. Then if still no luck do a rescan
Tried a rescn yet m8 ?
Been a while m8 but either set your location or look for an option to do a slow scan. i'm sure someone will tell you exacly how m8
as said select location if your image lets you what image are you on????
it kida goes like this but does depend on image what options you have:
1. Press "Dbox" on your remote
2. Select "services" from the menu
3. Select "Service Scan" (3rd down) from the menu
4. "Scan for Services" should be set to "TV & Radio" /vm style
5. "Bouquet" should be set to "Leave existing" press ok to scroll through
6. "Cable provider" should be set to Sym6887 for N*L or Sym 6952 for TellyPest /cable uk
7. "Fast Scan" should be set to off
8. Select "Start Scan"Comment
sorry little of topicas said select location if your image lets you what image are you on????
is it better to scan TV & Radio ?,just wondering cos i always scan - all services,thought that was what i should scan.
cheersComment
