ABOUT TO FLASH MY VERY FIRST IMAGE!!!
  • BONER
    • Sep 2009
    • 10
    i M ABOUT TO FLASH MY FIRST IMAGE ACCROSS THE COMMANDO ONE, BUT THERE IS A SPORTSTER IMAGE ALREADY ON, DO U HAVE TO REMOVE THAT IMAGE BEFORE YOU PUT THE NEW ONE ON, OR WHAT DO I DO????? CHEERS IM USING DBOX FLASHING ASSISTANT 3.2.1
  • Danril
    • 122
    You don't need to take the old image off first or anything like that fella. Don't worry, it will all be fine if you've done your reading and I'm sure you'll iron out any issues that may crop up with help on here if necessary.
    • xant14
      • 2062
      Owwww... my ears? why ru shouting? caps is considered shouting in discussions, and is rude. Keep the cap shift off mate.
      • BONER
        • Sep 2009
        • 10
        sorry bout that never knew you could hear me! Ive been flashing the commando onto the box how long does it take, been 10 mins now? maybe im just a bit impatient!
        • PaphosAL
          Old Git
          • 1064
          If you're flashing it to the correct location - /tmp - about 5 minutes from start to finish, usually- if your PC's NIC is set correctly? If it isn't, it can take forever- so just pull the power on the dbox, then do some more reading, m8!
          If you're trying to flash the image to a folder other than /tmp - then have a box of Kleenex tissues handy...
          Cheers- AL
          • Tommo1973
            • 181
            Cheers- AL [/QUOTE]
            With a username of "Boner" I reckon the tissues could be closer than we think
