I'm sure I'm not the only one whose seen this before. You may want to try this out and confirm your results here.
Using a fairly new image (2008); blade, andromeda, lincsat etc.
1) Using the Dbox remote, press the mute button.
2) Now with your TV volume, increase it to the MAX.
3) Press Dbox > Settings > Video > VideoOutput and set to "RGB + CVBS".
4) Keep your ears open for a buzzing noise. Now press OK to change to "CVBS".
Does your buzzing go away (if you had it with RGB setting) ?
Please confirm your results.
Thanks,
Menacez
Thanks,
Menacez
