Dbox flashing virgin.
  • backtozero
    • 6
    Excuse my ignorance, just trying to learn about the black art of flashing my Dbox.
    After reading this forum and others, as well as googling a few key points I am going to give it a go.
    I have a laptop with a wireless broadband connection, I assume it goes something like this:
    Download software to laptop.
    Connect laptop to Dbox2 using ethernet Xover and nullmodem cables.
    Transfer downloaded files to Dbox.
    Reboot box
    Hey presto Tv pictures again
    This simplifies it alot and no doubt I will run in to all sorts of problems, as long as I dont wreck the box.
    I want to pop my dbox flashing cherry
    If you already have an image on your box and can acces the dbox menu you can flash a new one wirelessly using only flash FTP or similar. If your box isn't already up and running and you want to flash an image on it, you need a xover cable and IFA. It will take about 5 mins or so thats all. Good luck m8, if you need any help just post
    • Devilfish
      Administrator
      • Feb 2008
      • 7872
      Yes as above, get yourself an FTP program, there's on in the download section.
      Get your PC talking to the dbox2 and then you're ready to flash.
      There's a guide here which will help you, it's for the dreambox box same principle.
      Dreambox Guides, Tutorials, Tips and Hints How to Connect your Dreambox to your PC
      Copy your img file to the /tmp folder on the box.
      Then, using the remote, do the following on the box...
      DBOX
      SERVICE MENU
      SOFTWARE UPDATE
      EXPERT-FUNCTIONS
      WRITE ONE PARTITION
      FLASH WITHOUT BOOTLOADER
      Select img file from the list and then ok.
      Image will be flashed, takes about 2 mins then the box reboots.
      When it comes back on it should have the new image on it.
      • Jocky666
        • 119
        Bigmaq dotcodotuk
        Files and fixes > Cable files > set top box files > Dboxs > Dbox2
        Et Voila
        Jocky
        Get the tool bar everything you'll need is there including guides etc.
        Reboot box
        • backtozero
          • 6
          Devilfish / Bulldog
          Managed to get my laptop talking to the Dbox through smartFTP
          I then was able to copy "commando9" into the tmp folder in the Dbox
          Followed your instructions and the image was flashed successfully, box rebooted - no channels! Any ideas?
          To be honest I just about managed to stumble my way through things and all was looking well yet still no channels.
          Help!
          • aftermath
            • 4345
            i believe that the commando9 image was stripped of the keys\roms\cables.xml
            so unless you can get hold of those from your old image, you wont be able to get anything just yet.
            • backtozero
              • 6
              Is it an easy fix - just copy flash another image?
              Any suggestions - Blade Quad, Boxcracker ?
              • sanchez
                • 13
                no channels after flash
                I have flashed a new image to my dbox2 (blade quad) but when i scan for channels it says there are none and to do a scan (which i am!). It reports no channels within seconds of starting the scan, any ideas?
                • plasterer
                  • 1631
                  You need to make sure its a full image mate
                  Were are you Downloading them From
                  Try Chatterbox tool bar
                  They are all up and running images .....Paul
                  PAUL
                  • sanchez
                    • 13
                    Paul knows what he is talking about, I dowloaded a Blade Quad image from Bigmaq, set my location, scanned for channels and it all works perfectly. very simple, cheers bro.
                    • bigalek1999
                      Great info, what image did you use and how did you go about downloading it or rather, where did you download it from?
                      • plasterer
                        • 1631
                        The Answerers to both questions are in the
                        2 previous posts mate
                        Were from = Chatterbox toolbar
                        Wot image = Blade Quad
                        Good luck ..............Paul
                        PAUL
