guys got a Sagem Dbox with BIG freezing problems.....
On the FIRST FREEZE UP....
Change it to ANY other channel then back to the channel you were watching.
It is fine for about 90 minutes to 2 hours then it will FREEZE again.
On the SECOND FREEZE UP......
Change it to ANY other channel ALL you get is the Mini bar Info Screen with NO PICTURE and a Dialogue box with ERROR ! CHANNEL NOT AVAILABLE ( this happens on all channels ).
YOUR'E ONLY ALTERNATIVES ARE......
1.REBOOT ( BUT IT WILL FREEZE AGAIN WITHIN 15 MINS ! )
OR
2.PULL THE PLUG OUT TO CLEAR AND RESET IT.
WHEN YOU GET CHANNEL NOT AVAILABLE
1.PULL THE PLUG OUT & PUT BACK IN AGAIN TO RESET IT.
2.WHEN OR IF IT FREEZE / HANGS UP. CHANGE TO ANY OTHER CHANNEL THEN BACK TO THE ONE YOU WERE WATCHING
3.DISPLAYS WORNG TIME IN CLOCK & PROGRAMMES ARE NOT UP TO DATE,.
ANY HELP ? Would be gratefull !
CHEERS for reading !
OR
PAUL
