Just another quickie devilfish please. I used to be a member of another forum and i understand why that was taken down and i fully understand the legal implications of images with keys but the images from the chatterbox toolbar do they contain these keys? If not is it just the key folder from a working image i need to ftp across and chmod 755? Many Thanks
Yes, if you have a working image, copy the /var/keys folder to your PC and that will work on any other image.
BUT....
Not all images are the same.
The proper rule is that all rom files go in /var/scce and all key files go in /var/keys. Some images have created a symlink (shortcut) from /var/scce to /var/keys so that all the key/rom files can be in the same place. Anything with a .bin extension should go in /var/scce, all other files in /var/keys.
If you're not sure, copy all the files to both folders.
All the Chatterbox images are ready for action
And need No additional add ons Just download and install the correct chip type for your Box .....Paul
If your Happy with the Help push the Thanx button PAUL
Thanks plasterer but i just get channel not available on non fta. Do i need to set my location and scan? and then maybe change cams or codes? have ftp'd my service file and bouquets
