new to dbox need help pls
  • MetMan
    • 1091
    #46
    Originally posted by cablefreejunkie
    i have just done everything you said and still no change,not sure where to go from here,im gonna try another scan and see if anything is different
    your service file look fine
    i email my img when u get it transfer into tmp....do what u did to back up but this time flash one partition without bootloader.
    • cablefreejunkie
      • 1717
      #47
      sorry mate,but how on earth do i perform a flash partition without bootloader ? when you send me the img i then transfer that into the said folder but the rest of what you said i dont have a clue how to do
      The control of information is the consolidation of power
      ?I care not what puppet is placed on the throne of England to rule the Empire. The man who controls Britain?s money supply controls the British Empire and I control the British money supply.? ? Nathan Rothschild
      IF I HELPED HIT THE THANKS BUTTON
      • smoggie
        • 863
        #48
        Using the DBox remote control, press (in this order)
        DBOX > SERVICE > SOFTWARE UPDATE > EXPERT FUNCTIONS > WRITE ONE PARTITION >
        FLASH WITHOUT BOOTLOADER
        Select the Image available (the one you just transferred over from PC) and select YES to flash
        The DBox will start to erase existing flash, and write the new one (this will only take a few minutes)
        The DBox will reset itself when done, and start up the new image
        this info is taken from a tutorial
        • cablefreejunkie
          • 1717
          #49
          when i select dbox the menu i get is as follows
          tv mode
          radio mode
          scart mode
          games
          1 audio player
          2 movie player
          3 picture viewer
          4 settings menu
          5 service menu
          6 sleeptimer
          shutdown
          if i select the service menu i get the following
          bouquet editor
          service scan
          refresh channel list
          refresh plug in list
          display u codes
          image update/back up/restore
          if i select the image update/back up/restore
          i get nothing to do with expert functions etc this is where im getting all confused i cant find anything to do with partition and flash without bootloader
          <--cablefreejunkie added 8 Minutes and 11 Seconds later...-->
          i have just looked in the nagra rom image menu and nagra rom 7 is disabled i have tried to enable it but i get an error msg saying no rom7 files available to enable/disable
          <--cablefreejunkie added 2 Minutes and 3 Seconds later...-->
          ive tried nagra 3 7 10 and 11 and all say the same thing
          Last edited by cablefreejunkie; 28 July, 2008, 17:59. Reason: Automerged Doublepost
          • MetMan
            • 1091
            #50
            tv mode
            radio mode
            scart mode
            games
            1 audio player
            2 movie player
            3 picture viewer
            4 settings menu
            5 service menu
            6 sleeptimer
            shutdown
            bouquet editor
            service scan
            display u codes
            does it say flash 1 partition....what r the commands? i've taken sportster back off my box now
            • cablefreejunkie
              • 1717
              #51
              when i select image/update/back up/restore i get the following
              flash read/write
              update mode internet
              then it says current version
              date 19.06.2005
              time 18.45
              release cycle 2.0
              image type release
              proxy server
              hostname
              username
              password
              search for new version
              surely all of the nagra rom 3/7/10/11 shouldnt be disabled ????
              • MetMan
                • 1091
                #52
                flash read/write
                date 19.06.2005
                time 18.45
                release cycle 2.0
                image type release
                proxy server
                hostname
                username
                password
                press flash read/write
                • cablefreejunkie
                  • 1717
                  #53
                  ah hah now i have
                  read whole image
                  write whole image
                  read one partition(back up)
                  write one partition(restore)
                  config file /etc/cramsfs.urls
                  so what next
                  • MetMan
                    • 1091
                    #54
                    ah hah now i have
                    read whole image
                    write whole image
                    so what next
                    write one partition......the img is in the tmp folder?? cause if u reboot the box u lose it.....
                    • cablefreejunkie
                      • 1717
                      #55
                      i have the new img file on my desktop how do i flash it ? i think i know but i want to be 100% sure first
                      • MetMan
                        • 1091
                        #56
                        ftp the new img into the tmp folder and use the instructions listed above. when u get to the final command flash without bootloader you should see file selector - choose the img press ok - it will ask r u sure? click on yes....wait, allow to flash do not turn box off - should reboot on its own
                        • zaf786
                          • 327
                          #57
                          Put your image in tmp
                          Then go to services down to backup and restore then you want to press on flash/write then write one partition then choose flash without bootloader select your image and wait for the box to be flashed and it willreboot itself when it,s finished
                          <--zaf786 added 0 Minutes and 59 Seconds later...-->
                          Originally posted by MetMan
                          ftp the new img into the tmp folder and use the instructions liseted above. whem u get to the final command flash without bootloader you should see file selector - choose the img press ok - it will ask r u sure? click on wait....allow to flash do not turn box off - should reboot on its own
                          Beat me to it mate
                          • MetMan
                            • 1091
                            #58
                            Originally posted by zaf786
                            Beat me to it mate
                            i'm close to slitting my wrists here........not too sure if this isn't a wind-up
                            • cablefreejunkie
                              • 1717
                              #59
                              it now says do you really want to write to flash ?
                              if an error occurs or the image is not valid,the box will not boot after flashing.
                              imagename mtd3.img
                              target:flash without bootloader
                              yes no
                              what to do ??? yes or no ?
                              • MetMan
                                • 1091
                                #60
                                imagename mtd3.img
                                yes no
                                press yes and let it do its work
