Gavs # Final # Image out
  • gav12345
    • 85
    Gavs # Final # Image out 2x
    a fond farewell from me as no more dbox so no more images
    enjoy!!
    with thanx for devilfish to get this out for no Keys or Roms
    gav12345 introduces the Gavs-Final image
    very smooth channel changing
    fast scanning fixed and plugins for it has been modified
    has all updates working too online
    no Keys or Roms----
    lcd epg all ready to go
    Tv on Lcd switch via blue button
    camd updates online too via blue button
    remember to delete camds before updating
    plugins update via blue button - gavs GLJ
    setup fast scan via blue button
    file manager via blue button
  • zaf786
    • 327
    Hi thanks gav excellent image as usual u will be missed i hope you can sort your self a another box also ihave converted to1x if someone intrested
    • Derekwd
      • 244
      Same here gav m8 you will be missed, the dbox scene has already lost a lot of modders to the dreambox dont want to lose another top one.
      Derek
      • MetMan
        • 1091
        posted this on another forum......
        just flashed it over and added the necessary files - well impressed....gr8 start up lcd, blue button function works flawlessly, channel change is smooth, fast , pic quality gr8, cant fault it thanks very much gav...
        spoke to soon just noticed the infobar is doing something strange, it scrolls left / right ok but soon as you try to view future programs it only shows programs from the channel the box booted to, it doesn't matter what channel ur on it always shows the 1 channel......never seen this b4
        • gav12345
          • 85
          thanks to all
          @neathdrew
          i think to get full epg its red then green and works great
          the info bar left right is for now and next only
          the sectionsd is a cut down version to make the image really smooth thats all and that why its like that i do believe
          hope all else is ok
          enjoy
          • gizmo.1484
            • 873
            Thanks for another great image Gav
            Sorry to see that this is the last one you will be missed....
            Hope you stick around the dbox scene has you are a legend image builder.
            Peace
            • zaf786
              • 327
              Hi hit a problem with this image for some reason it is hanging on bootup
              • gav12345
                • 85
                sounds like you need to reflash it
                or its a 1x 2x problem
                ifa english 2.5 always works great for me well used to anyway
                • zaf786
                  • 327
                  Hi i reflashed it again it was 2x image
                  • gav12345
                    • 85
                    try another working image and do a transfer to tmp folder and then flash through the menu options see what that does then
                    • zaf786
                      • 327
                      Hi i had your image working last night i was watching it till about 1am but this morning it won,t boot up it was strange
                      • gav12345
                        • 85
                        could be the vm are messing in your area as they are playing with the broadband
                        at the mo
                        try another image that works first then flash through the menu options see what that does then
                        • bloodstone1964
                          • Aug 2008
                          • 33
                          • kamal2kool
                            • Aug 2008
                            Help needed!!
                            Hi Im new. is the image reay to go or is there other files needed? Im use to plug and play so if someone can give me an email which i can understand that would be great. Thanks
                            • Renwich
                              • 125
                              we were all new at some point m8, a simple search will provide you all the info you require, if you can flash an image, copying a few files out of your working image shouldnt be a biggie
                              Learn how to mod Dbox images
                              PT-1's latest helpfile
